stevec
| posted on 15/9/07 at 08:54 PM |
One for the turbo experts.
I am running the standard Rover 1.8 Turbo set up.
I am getting a very loud light throttle hissing from the area of the air filter.This goes away when more load is applied and is not there at full
throttle. This is not the same noise as the usual induction roar. it sounds more like a compressed air gun. The air filter is a K&N capable of use
on twice the power output of mine so I dont believe its restrictive.
Due to lack of space the air filter is in the passenger footwell so this makes it more noticeable. I reckon I will probably have to live with it.
Any clues anyone?
Cheers.
Steve.
oadamo
| posted on 15/9/07 at 10:00 PM |
if its a hissing its a leak on the compressor side. do you have a bleed valve.
adam
stevec
| posted on 15/9/07 at 10:43 PM |
Its hissing before the boost gauge is reading positive pressure and the noise is from the inlet side,
Steve,
PAUL FISHER
| posted on 15/9/07 at 10:49 PM |
Sounds like its the turbo waste gate fluttering,opening and closing to me.this is the noise you here each time you change gear,or throttle off.With
the noise going away under engine load,if it was a leak on the pressure side I would expect it to be hissing louder under full throttle and boost.And
with you having the induction in the footwell as I have on my car this noise will be amplified.
Fatboy Dave
| posted on 15/9/07 at 11:01 PM |
More likely to be the recirculating dump valve being open on part throttle. At light throttle the turbo is most likely not making boost therefore the
wastegate will be closed and thus silent.
When I got my first Rover turbo (a 620Ti), I was alarmed at some of the noises the stock recirc DV used to make when I binned the air box and fitted a
chav filter...
Dave
Stop the planet, I want to get off
grub
| posted on 16/9/07 at 07:11 AM |
is there much float on the impeller, and its not rubbing on the compressor housing just a thought i know that makes a strange noise??
stevec
| posted on 16/9/07 at 09:40 AM |
Turbo and engine are New. No play in anything.
Steve.
martyn_16v
| posted on 16/9/07 at 04:14 PM |
How far is the throttle from the air filter/end of the inlet? One of my old cars used to hiss like a python being bothered by Steve Irwin at part
throttle, it was just air rushing past the nearly closed throttle butterfly. Just put your foot down
