Gixer Indy
| posted on 16/9/07 at 11:36 AM |
engine holding back!
While out for a blat yesterday noticed engine holding back at full throttle,(half way through an overtake, not the best place to play silly
buggers!)back off throttle a bit and power returns!!! where should i start fiddling?
Flat out til you see God, then BRAKE!
zilspeed
| posted on 16/9/07 at 12:24 PM |
Fuel.
Choked jet(s)
Clogged filter
Weak pump.
| posted on 16/9/07 at 03:40 PM |
Fuel flow problem ---- not enough fuel getting through to float chambers.
First place to look is for a problem between the suction side of the pump and the tank.
Gixer Indy
| posted on 16/9/07 at 03:41 PM |
cheers,
was thinking fuel problem, will check it out.I didn't build the car so not sure if everything is as it should be,found a few bodges in other
areas so far!
Gixer Indy
| posted on 16/9/07 at 04:03 PM |
Sorry, should have mentioned it's a gsxr 1000 k2 engine, fuel injection, looks like fuel pump from the doner bike,is that up to the job?
