Hammerhead
| posted on 18/9/07 at 10:22 PM |
Engine mountings
Do they need to be beefier? The box section is about 2mm thick and the plate is 5mm.
Cheers.
Steve.
RazMan
| posted on 18/9/07 at 10:27 PM |
I would say that the box section looks a bit weedy imo, especially as the mount is quite long.
Raz
blakep82
| posted on 18/9/07 at 10:33 PM |
2" square box maybe? 5mm plate seems alright though
________________________
graememk
| posted on 18/9/07 at 10:34 PM |
with the length and angle i'd beef it up a bit
| posted on 18/9/07 at 11:16 PM |
I used 40mm square box with a 3mm wall to make my engine mounts
| posted on 18/9/07 at 11:17 PM |
bottom one needs a curved fillet to the top of the bolt tube. Top needs a bit more thought IMHO, nice cutting at least! Couple of fillets to spread
the load should sort it though.
stuart_g
| posted on 19/9/07 at 07:46 AM |
I would try to add a brace going back to the rear of the engine making a V shape if there is anywhere to fix it to. If not then the box section needs
to be bigger IMHO. I think that when the engine rocks it will eventually break the mount.
Angel Acevedo
| posted on 22/9/07 at 03:53 AM |
The mount is flexing as it is,
it would be better straight down.
Reposition the lower mounting plate that way you shorten the mount and make it work in compression
