Author: Subject: Air \ power shifter?
lsdweb
posted on 19/9/07 at 09:23 PM Reply With Quote
The conversion from 5JJ to 5VY is a lot more tricky than we originally thought! One of the most difficult bits looks lke the gear linkage as the gear selector mechanism is far closer to the centre of the car than previously (mid engine setup) . This means that the old linkage (direct rod to gear lever) won't work. The solution looks complicated so I'm thinking of using a power / air shifter to simplify things and gain the advantage of this kind of system.
Anybody using one? Any recommendations?
Regards
Wyn
bigrich
posted on 19/9/07 at 09:33 PM Reply With Quote
i think Chris Mason is using a trick gear shift set up with paddles or have a look at this link, no connection but is run by an ex bike racer whos a mate of a mate
http://www.racegadgets.com/
Rich
Paul TigerB6
posted on 19/9/07 at 09:43 PM Reply With Quote
Something like this mate??
http://www.locostbuilders.co.uk/viewthread.php?tid=70315
lsdweb
posted on 21/9/07 at 05:12 PM Reply With Quote
Thanks guys.
That's the kind of stuff I'm looking at. I'm going to 'visit' my car tomorrow so I'll have nother look t it again. A simpler option may be to extend the shaft towards the side of the car, maybe with a bearing / rose joint, and use the existing linkage.
Wyn
