Author: Subject: Head Gasket
DorsetStrider
posted on 20/9/07 at 03:33 PM Reply With Quote
Head Gasket
Hey guys,
Does anyone know how easy/hard it is to change a head gasket on a fiat cincento?
I know the theory behind changing a head gasket but have never actually done it before... are fiats particularly tricky? Advise as always very gratefully recieved.
Who the f**K tightened this up!
theconrodkid
posted on 20/9/07 at 03:44 PM Reply With Quote
10 min job,leave the inlet manifold on when you take the head off,get it skimmed,they burn through between1 and2 if i remember rightly
who cares who wins
pass the pork pies
Ask someone with a K-series engine, they'll be an expert
I think the hardest bit is scraping off the old ones without getting shite into the cylinders and water galleries.
skydivepaul
posted on 20/9/07 at 03:46 PM Reply With Quote
unlike changing the head gasket on a renault kangoo van!!!
spent all day stripping out the turbo and timing gear etc and just got the head off - 8 hours
i am out of practice though
http://www.smartideasuk.com
http://www.smartmapping.co.uk
HD CCTV
IP security systems
access control systems
stevec
posted on 20/9/07 at 04:10 PM Reply With Quote
Had the wifes head off twice now on her Clankyclunko. Its a doddle, Hydraulic lifters on the rocker shaft tend to pump out while it is off and make it a pig to start afterwards but just keep cranking
Steve.
[Edited on 20/9/07 by stevec]
froggy
posted on 20/9/07 at 07:59 PM Reply With Quote
can you start at my place monday morning then if your that quick ive got a tdci focus and a grand voyager in for head gasket so you should have them both done for lunchtime
posted on 20/9/07 at 08:13 PM Reply With Quote
I work mainly with Rovers but have changed a lot more blown Fiat head gaskets than K series.
With Fiats it is an age/mile thing -- they nearly all go, I suspect the cause is stress relaxation -- low temperature creep.
Usually an easy fix unless the engine has been roasted.
A K series will only suffer head gasket failure if run without a circulation of coolant --- ie cooling system air locked due to water loss or habitually abused and revved hard from a cold start before the thermostat has had a chance to open.
