bassett
| posted on 21/9/07 at 08:42 AM |
Equivelant to alpha weber performance package
Hi just wondering if theres any cheaper product out there to get and set up carbs for a 2.0L zetec, if any one could give me some prices, and
suppliers and possible power outputs that would really help
Paul TigerB6
| posted on 21/9/07 at 09:19 AM |
Well there's bike carbs / megajolt for starters. You could buy it ready made or save money and do it yourself.
http://www.tiger-super-cat.co.uk/csc/carbkit.htm
JAG
| posted on 21/9/07 at 09:24 AM |
A friend of mine has a Megajolt on a 1.8 Zetec with twin 40's in a Westfield and he's very pleased with it.
He built it all himself and programmed it using a map off of someone else running a similar set-up. It goes very well and runs really smoothly.
He had a Weber Alpha system before this and when it packed up the guys at Weber Alpha wouldn't help him or repair it because it was no longer in
production. They offered him 10% discount on another system for over £300
Justin
bassett
| posted on 21/9/07 at 09:33 AM |
Is the carb and megajolt kit pretty straight forward and where can we source these parts?
Also with fitting a zetec would we need anything else and where can we get a shortened or baffled sump? and is the lightened flywheel necessary or
recommended?
Paul TigerB6
| posted on 21/9/07 at 09:46 AM |
You could try here for starters for a megajolt (carbs) or megasquirt (injection) ... http://www.locostbuilders.co.uk/viewthread.php?tid=74351
for the manifold there are a couple of companies - Bogg Brothers i believe are the major supplier http://www.boggbros.co.uk/index.html
Carbs can be bought off ebay - or you could consider going to throttle bodies and have a fuel injection set up. This might not be easy / cheap though
depending on your current fueling system though if you are set up for carbs but can be done with a fuel swirl pot / inj pump.
There are loads of threads on this subject so try a search and you will learn plenty to be getting on with.
Which Mondeo engine are you fitting?? The sumps are totally different between the silver top and black top versions. You could start off having a look
here anyway http://www.zetec-cat.co.uk/
[Edited on 21/9/07 by Paul TigerB6]
mcerd1
| posted on 21/9/07 at 10:12 AM |
I'm building my pinto at the moment with bike carbs and megajolt
but the megajolt is easier to fit to a zetec than my pinto
I got built up megajolt from paulf on this forum for £87.50 delivered (I think he might have a couple left for sale at the moment)
I got the ford ignition bits (inc. loom) from a local(ish) scrapyard for £30 (£40-50 max on ebay)
a set of plug leads - just the std. zetec ones to suit the coil pack that you get
My carbs are late model ZX9R ones - they came from bogg bros. on and alloy mainfold for £350 all up (inc. first guess jetting)
ask bogg's for a price for the whole lot and a price if you supply the carbs (you might get them cheaper if your lucky)
then a session on the rollers at to jet the carbs properly (~£70 at bogg's) but you'd do this with webbers anyway
only issue is not all rolling roads will tune bike carbs
also you'll need a foam filter or airbox - more or less same as you'd need for twin webbers
so total cost should be less than £550 assuming you have to buy everything
but if you make your own manifold, jet your own carbs and build your own megajolt you could save lots of £££
heres a guide to fitting megajolt to a pinto (mostly the same for a zetec)
http://www.cate1.co.uk/megajolt/index.php
[Edited on 21/9/07 by mcerd1]
