prelude1980
| posted on 22/9/07 at 02:42 PM |
Blacktop Timing Mark
As above i can see the small notch out of the pull but what do you line it up with to do the timing
Speed has never killed anyone. Suddenly becoming stationary... that's what
gets you.
https://www.topcashback.co.uk/ref/dodd1980
| posted on 22/9/07 at 03:30 PM |
Think its the same as the silver top , timing mark is on the end of the sump at approx 4 o'clock.
prelude1980
| posted on 22/9/07 at 04:28 PM |
had a look seems to be a raised mark there but its about 5-6mm wide, would you time it off the middle of this?
gets you.
| posted on 22/9/07 at 04:31 PM |
From memory it is wedge shaped with one side of the wedge lining up with the center of the pulley bolt , that is the side to use the other side is way
out of line. . Also check the pulley as it may have two marks about 25mm apart,if so when turning engine in direction of rotation use the second mark.
prelude1980
| posted on 22/9/07 at 05:06 PM |
cheers i'll try that see how it goes
gets you.
THE BEAR
| posted on 27/9/07 at 07:24 PM |
PRELUDE1980 iam just up the road from you lol if you fancy meeting there is a cpl of us in bridgwater that meet up have you any pics of the front of
your engine as to where your belts are going many thanks
