Poll: EFI fuel pumps [View Results]
External EFI pump
In-tank EFI Pump, but which?
Author: Subject: EFI fuel pumps
scutter
posted on 28/9/07 at 05:07 PM Reply With Quote
EFI fuel pumps
Ok Ladies and Gents, I've made a new fuel tank and at the mo it's virginal not a mark on it.
Do i add a swirl pot and use an external pump and filter? or weld on a plate to take an in-tank pump unit?
Which in-tanks pumps are suitable? and does anyone have a picture of the mounts for these pumps. Also do the internal pumps have a built in swirl pot/catch tank?
Sorry for all the questions but i don't fancy making another tank
ATB Dan.
[Edited on 28/9/07 by scutter]
paulf
posted on 28/9/07 at 05:21 PM Reply With Quote
I think you will need to make some sort of internal swirl pot if using an in tank pump, i thought about the idea when i did my injection but setteled on an external bosch pump and swirl pot.
The other alternative is a compromise of both methods by putting an extension pot on the bottom of the tank with a pipe feeding an external pump, this may be easisest to do but I decided that it would look untidy as the swirl pot would have stuck out under the rear chassis rails and been visible from behind.
Paul.
scutter
posted on 28/9/07 at 05:28 PM Reply With Quote
Well thats sorted that then as the tanks fully welded with no chance of adding any internal swirl pot.
Is a safe bet for a swirl pot about 1L capacity?
ATB Dan.
scutter
posted on 28/9/07 at 05:39 PM Reply With Quote
Probably the shortest poll ever
ATB Dan.
paulf
posted on 28/9/07 at 05:45 PM Reply With Quote
Mines about a litre , try and make it tall and thin rather than large dia and short.
I used a bit of stainless tube about 80 dia .
Paul.
ATB Dan.
