Author: Subject: Automatic Zetec donor any good?
GaryM
posted on 29/9/07 at 08:51 AM Reply With Quote
Hi
Would an engine out of an auto 1.8 Zetec Mk2 Mondeo be suitable for replacing a 1600GT Xflow (connected to a type 9)?
Gary
posted on 29/9/07 at 10:38 AM Reply With Quote
Should be, but you'll need the flywheel, sump and water pump from a 1.8 Escort to make it fit.
jambojeef
posted on 29/9/07 at 03:43 PM Reply With Quote
You also might need to have the spigot bearing that usually supports the clutch and flywheel pressed into that engine.
Engines with torque convertors dont usually have them fitted.
big_wasa
posted on 29/9/07 at 04:27 PM Reply With Quote
And you will also need the crank position sensor housing from a manual aswell
Werner Van Loock
posted on 29/9/07 at 05:10 PM Reply With Quote
You also need the housing for the trigger sensor as it is different on the auto.
http://www.clubstylus.be
grusks2
posted on 29/9/07 at 09:01 PM Reply With Quote
Im running a 2L auto engine -
I fitted a 1800 flywheel, spiggot bearing, new trigger housing ( the sensor is ok from the auto) the sump i had cut and shut.
I used an 18cvh sierra starter.
http://mac1worxbuild.wordpress.com/
forgot my old password so another username doh
