Author: Subject: gearbox to suit alfa v6?
Pezza
posted on 1/10/07 at 10:30 AM Reply With Quote
Getting rid of the van as a daily driver and am looking at a mk2 or 3 cortina for some medium pimping
Like the idea of dropping an alfa v6 in rather than the usual pinto/zetec/v8 conversions.
Anyone know what gearbox you can use for a rwd tina?
is there an alfa box to suit?
Plan will be to do it as cheap as possible.
Ben
You couldn't pwn your way out of a wet paper bag, with "PWN ME!!" written on it, from the "pwned take-away" which originally contained one portion of chicken tikka pwnsala and the obligatory free pwnpadom.
James
posted on 1/10/07 at 10:58 AM Reply With Quote
Johnmor (I think) on here has fitted an Alpha in his Viento.
He had to make his own bell-housing to bolt to a Type9.
There was an article about it in PPC a year or 2 ago.
HTH,
James
mangogrooveworkshop
posted on 1/10/07 at 11:03 AM Reply With Quote
HTH,
James
John used an Alfa FWD gearbox bellhousing mated to a type 9 box via an adapter plate
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=DSCF0067%20(Medium).JPG
John.Taylor
posted on 1/10/07 at 11:37 AM Reply With Quote
Why not buy an Alfa 75 3.0 V6 complete with trans-axle gearbox, prop, driveshafts etc.
Pezza
posted on 1/10/07 at 11:42 AM Reply With Quote
Doubt the transaxle will fit
NS Dev
posted on 1/10/07 at 12:32 PM Reply With Quote
John used the fwd box, as was said, just for its bellhousing.
He chopped it off just behind the back of the bellhousing (just behind the "front" bearing plate) then made an adapter plate and drilled and tapped this to the milled flat end of the alfa bellhousing.
I would say this is easily the easiest way to do it, as you can keep the alfa hydraulic release mechanism etc.
ZEN
posted on 1/10/07 at 02:59 PM Reply With Quote
How about a gearbox from an Alfa 6?
[Edited on 1/10/07 by ZEN]
My YouTube channel Cars, bikes - track days, motorsport, sim racing and more.
Trev Borg
posted on 3/10/07 at 08:31 PM Reply With Quote
The alfa 6 gearbox is rare as rocking horse poo.
Like its said above, john used the alfa gearbox bellhousing with an ally adapter plate, and hydraulic clutch.
Myself and Mr Owelly turned to the dark side and made steel bellhousing to suit
alfa V6 genimi
Owellys pile of poo
Before you judge a man, walk a mile in his shoes.
By that time, who cares.
You're a mile away, and you've got his shoes
Johnmor
posted on 4/10/07 at 09:37 PM Reply With Quote
Alfa gearbox
All above are correct, sorry not posted sooner, been away.
The gearbox and clutch are still going no problem,
But talking of rocking horse pooh, I have aquired a gearbox from an Alfa 6 , but it is a 4 speed automatic.
Still- never look a gift horse in the mouth. (pooh or otherwise)
