robertst
| posted on 2/10/07 at 04:26 PM |
its christmas!!!
just received the assembled megajolt from the u.s. AND the R1 carbs i got from ebay in the same week!
whats more the carbs came spotless with the airbox trumpets AND the manifold rubbers (i was really not expecting them)
heres a pic
  R1 bike carbs
now i need some help identifying its parts. i gather some in this pic are correct? what is the piece with the ?? i think its the t-piece everyone
talks about but i dunno what it does.
  identifying parts
also, what is this sneaky little tube for? theres a smaller one at the other side.
finally, how does this open and close?
sorry for the ignorance.. i'm quite unfamiliar with these carbs.. not much info on the net i suppose...
any help appreciated
Tom
[Edited on 2/10/07 by robertst]
Tom
takumi
| posted on 2/10/07 at 04:48 PM |
Hi there,
Lets just clear up a few things.
1:
What you have labelled 'Choke' is the fuel cut-off, this slide needs to be held open with a small spring or cable tie in order to run.
2:
What you have labelled 'Fuel inlet' is an oil vapour seperator, normally goes to the crank case, and when under inlet vacuum draws the oil
vapour into the inlets and burnt off.
3:
What you have labelled '???' is the fuel bowl vents, these simply allow excess fuel vapour to 'vent', normall fed back to the
air box, or just to atmosphere with little foam filters to stop bits going down..
4:
What you have labelled 'Mixture Screw' is the idle speed screw, you will see that it moves the throttle stop. The idle mixture screw, is
normally just behind and below the throttle plates,.
5:
the black plastic slides inside the carbs, are the variable chokes, they will move up as the revs increase and the manifold pressure changes. They
ensure that air speed is fairly constant through the carbs at all throttle openings, this means better fuel economy and good low rpm torque..
Have you got a photo of the throttle plate side, ?
[Edited on 2-10-07 by takumi]
RobinHood 2B 2.0i pinto, Keihin 38mm Carbs, lightened flywheel, O'Mori remote filter kit, 10 row oil cooler. Modified head, 10.2cr, special
valves FR22 cam, 4- 1 header.
robertst
| posted on 2/10/07 at 04:53 PM |
cheers for clarifying it up for me... had no idea... about the fuel cut-off cable, if i pull it does it let fuel in or does it cut it off?
and the crankcase thingy can i just leave it as is? no need to connect it to anything?
so i guess the fuel inlet is the sneaky little tube in the third pic?
is this the pic you needed?
  other side
Tom
Pdlewis
| posted on 2/10/07 at 04:56 PM |
i agree with above apart from you did correctly lable the choke and it does not need to be held with a spring (i am running r1 carbs)
The fuel inlet is on the bottom copper pipe ignore the silver heating pipes not needed
andyharding
| posted on 2/10/07 at 04:58 PM |
1:
Bollocks it's the choke!
robertst
| posted on 2/10/07 at 04:59 PM |
so is this one of the heating pipes?
Tom
takumi
| posted on 2/10/07 at 05:01 PM |
Naughty me,
I've just looked back over my mikuni service manual,
and yes..
That is the Starter Cable..it actuates the Starter Plungers..
Pdlewis
| posted on 2/10/07 at 05:06 PM |
Yes that pipe is the heater circuite and not used
Takumi - The idea of a choke (although i dont need it) is it needs to be open to start the engine. if you are holding this open it will be running
way to rich!!!
takumi
posted on 2/10/07 at 05:11 PM |
might be why it failed the emissions
bummer..
locoboy
| posted on 2/10/07 at 05:31 PM |
Can confirm its choke.
I never needed mine even from a cold start having stood for a week.
If i was starting it when not in the car then i would manually rev the engine a little when cranking and when in the car a couple of blips on the
throttle were enough to make it start when cranking.
Locoboy
robertst
| posted on 2/10/07 at 05:48 PM |
SERVICE MANUAL??? where did you get that???
Tom
takumi
| posted on 2/10/07 at 06:01 PM |
p2p
smart51
| posted on 2/10/07 at 06:34 PM |
What is labled "fuel intake" in the pic is actually a breather. The fuel inlet is underneath, to the right hand side of the photo.
The sliders pointed to by the arrow slide all by them selves.
robertst
| posted on 2/10/07 at 07:19 PM |
oh so its this one then???
Tom
Pdlewis
| posted on 2/10/07 at 07:23 PM |
on your intial post there is a pipe next to a blue tissue thats the fuel inlet
westf27
| posted on 2/10/07 at 08:27 PM |
quote: Originally posted by andyharding
1:
Thats a rude word isnt it,how very dare you
takumi
| posted on 2/10/07 at 09:04 PM |
Thats what I thought..
takumi
| posted on 2/10/07 at 09:06 PM |
That small pipe arrowed, looks like it could be a vacuum take-off..
dave1888
| posted on 2/10/07 at 09:42 PM |
Choke aint a bad sorry.
