whitestu
| posted on 2/10/07 at 07:29 PM |
Bike Carb Balancing
Am I right in thinking the vacuum take off for balacing bike carbs is normally on the inlet rubbers?
I haven't done any for years and can't remember!
If so how do people balance bike carbs if using silicone hoses to join on to the manifold?
Stu
givemethebighammer
| posted on 2/10/07 at 07:54 PM |
I use one of these
http://cgi.ebay.co.uk/CARB-BALANCER-WEBER-DELLORTO-S-U-CARBS_W0QQitemZ170154703502QQihZ007QQcategoryZ72205QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
works for me
jacko
| posted on 2/10/07 at 07:59 PM |
quote: Originally posted by givemethebighammer
I use one of these
Hi I use one very similar to that
Jacko
works for me
| posted on 2/10/07 at 08:32 PM |
I thought most bike carbs had take-off tubes for use with a Carbtune or similar device... (4 bits of clear tube with some coloured water in)
thunderace
| posted on 2/10/07 at 09:16 PM |
http://cgi.ebay.co.uk/Vacuum-Gauge-Honda-Harley-Kawasaki-Yamaha-Suzuki-4-cyl_W0QQitemZ120166428847QQihZ002QQcategoryZ25623QQssPageNameZWDVWQQrdZ1QQcmd
ZViewItem
thats what you use for bike carbs.
takumi
| posted on 2/10/07 at 09:20 PM |
use some rubber tube
much cheaper to use a piece of 1/4" pipe or tube, feed that into the carb up against the throttle plate,
and listen to the pitch of the air rushing as its being drawn past the throttle..!
much quicker to balance this way than connecting up a vac guage.!
worth a try anyway as its essentially FREE !
RobinHood 2B 2.0i pinto, Keihin 38mm Carbs, lightened flywheel, O'Mori remote filter kit, 10 row oil cooler. Modified head, 10.2cr, special
valves FR22 cam, 4- 1 header.
OX
| posted on 2/10/07 at 10:49 PM |
you can buy cheap mercury ones that are better than the dial type but they are sensitive .
lol listening to it may be free but i doubt you'd get them anywhere near the mark as you only get 3 adjusters for the 4 carbs so as you adjust
one the other one goes the opposite way
i use this to set up mine
[Edited on 2/10/07 by OX]
bob
| posted on 3/10/07 at 08:19 AM |
I used the gunsons carbalancer with good effect, best shop i found for price and postage was here
lnky
scroll down to the bottom of page.
Good part is the fact you do not have to be a member.
whitestu
| posted on 4/10/07 at 10:09 AM |
I have a bike carb balancer - what I can't remember is whether the vacuum take off is on the carbs [I can't see one on my ZX6R carbs] or
on the inlet rubbers.
Stu
Jimbob
| posted on 4/10/07 at 12:10 PM |
On the zx9 its a tapped hole into the inlet
port on the block just below where the
inlet rubbers bolt on so not on the rubbers themselves
I imagine the zx6 is similar
whitestu
| posted on 5/10/07 at 08:43 AM |
Dingz
| posted on 5/10/07 at 08:02 PM |
I used a piece of tube and my ear, then not believing that method, borrowed a plug in balancer thing and found they were so close it wasn't
worth tweaking them.
takumi
posted on 8/10/07 at 11:23 AM |
see.! the simpiest methods are the best..
