jimbona2
| posted on 3/10/07 at 11:34 AM |
engine positioning
this is actually from another thread regarding the engine posiitoning. does anyone think the engine looks higher at the back. Any suggestions why
this might be.
Would it be something with the engine mounts or something to do with the clutch area?
thanks
azzacat
| posted on 3/10/07 at 11:40 AM |
Yup looks odd, but may be normal for a Tiger, Check your gearbox mount, it just looks like the box is to high to me.
Although it has been known for tiger to send the wrong engine mounts out, pop your exhaust on and if the can is up high then its wrong..
Other than that looks like a nace build!!!
Well done!
Aaron
jimbona2
| posted on 3/10/07 at 12:15 PM |
well i havent got the fuelling system yet although i'm getting that when I get paid!!
Paul TigerB6
| posted on 3/10/07 at 12:20 PM |
have you got a picture of the gearbox mount?? Looks to be sitting rather high to me.
Paul
flange nut
| posted on 3/10/07 at 12:24 PM |
This may be a stupid question, but have you got the rubber engine mounts fitted between chassis and engine?
Geoff
jimbona2
| posted on 3/10/07 at 12:32 PM |
is this okay
jimbona2
| posted on 3/10/07 at 12:33 PM |
mounts are there.
donut
| posted on 3/10/07 at 12:41 PM |
I had a similar issue with my MK Indy with Pinto engine and they said that the engine should look like it's pointing down at the front so it
looks fine to me.
jimbona2
| posted on 3/10/07 at 12:51 PM |
ok thanks for the vote of confidence. when I get the exhaust inlet i'll let you know..
AdamR
| posted on 3/10/07 at 01:00 PM |
Looking at your pic of the gearbox mount, is it possible to bolt the cross member up to the chassis from underneath? That's how they usually
work AFAIK and would drop the box by about an inch by the looks of the pic, thus lining things up a bit better.
NS Dev
| posted on 3/10/07 at 01:03 PM |
As above, bolt the gearbox mount to the underside of the box section, not the top.
It will then probably be slightly nose down but less so. Certainly doesn't look right at the mo.
Mine is a touch nose down but not that much
jimbona2
| posted on 3/10/07 at 01:09 PM |
will that affect the ground clearance?
| posted on 3/10/07 at 01:19 PM |
looks fine to me.
they just said that to keep you quiet
It probably does not matter that much providing the bulge in hte sump is filled with oil for the pick up to pick up the oil.
.... and a good way to figure out how things should likne up is to look how the original manufacturer fitted the engine. Looks like you have zetec so
thatwould be mounted in the frotn, transversely and as far as I am aware, all fwd cars I have seen, whcih is not many, have the cam covere top
horizontal hence my initial comment.
Also I would guess the bottom face of the bock should be horizontal.
takumi
| posted on 3/10/07 at 01:27 PM |
Mount the gbox mount under the box section for sure..
I spent a while making my engine and gbox mount for my about to be scrapped chassis.. so my engine and gearbox are dead horizontal and parallel to
the chassis.
>just hope they still will be in the new chassis..:S
RobinHood 2B 2.0i pinto, Keihin 38mm Carbs, lightened flywheel, O'Mori remote filter kit, 10 row oil cooler. Modified head, 10.2cr, special
valves FR22 cam, 4- 1 header.
bob
| posted on 3/10/07 at 02:14 PM |
I keep looking at the gearstick ..... might be an optical illusion but it does look like the engine/gearbox needs to come back a few inches.
To me it looks like the scuttle may cover the geardtick
welshavon
| posted on 3/10/07 at 02:45 PM |
I went through the same dilema with my Avon, and eventually came to the conclusion that the engine does sit nose down. I've put an image in my
archive that shows it. As for fitting the gearbox mount under the chassis rail I was advised against this because if the nuts should work loose the
gearbox would drop with dire consequences. With the mount on top and the bols fitted from the top you have a degree of safety should the nuts come
loose.
Colin
Thinking about it
| posted on 3/10/07 at 04:19 PM |
Should it be level? So that the output of the gearbox and the input on the diff are parallel.
bob
| posted on 3/10/07 at 04:30 PM |
drop the bonnet and nosecone on to see how much room you have from the top of the engine or cam belt cover, you may be able to space the engine mounts
a bit to get the engine a bit more level.
At the angle your at now the prop to diff would be glad there is a UJ at each end, i was told when fitting my eng/box to try and get the prop as level
as poss so as to not overwork the UJ's.
Kinda made sense to me
AdamR
| posted on 3/10/07 at 04:31 PM |
quote: Originally posted by welshavon
As for fitting the gearbox mount under the chassis rail I was advised against this because if the nuts should work loose the gearbox would drop with
dire consequences. With the mount on top and the bols fitted from the top you have a degree of safety should the nuts come loose.
Colin
The gearbox mounts/cross members bolt up underneath on lots of production cars out there. You are supposed to be able to remove the cross member from
underneath the car to give yourself space to drop the box down and remove the engine/box from the car. I certainly couldn't remove my engine
from my 7 chassis without being able to drop the mount off the bottom.
There should not be any problems with nuts loosening.
AdamR
| posted on 3/10/07 at 04:39 PM |
Not necessarily. Ideally there should be small angle in each UJ to avoid premature wear.
Therefore it's a good thing if the gearbox/diff flanges at different heights BUT the mounting faces must be exactly parallel at each end of the
prop so that the angle on each UJ is the same.
HTH
flange nut
| posted on 3/10/07 at 05:52 PM |
I've just had a look a Jim Dudley's book and it shows the gearbox mount bolted on top of the box section. It also looks like the front of
the engines do point downwards. Looks like it's necessary to get under the bonnet.
Geoff
jimbona2
| posted on 3/10/07 at 07:48 PM |
im reading this like your saying how I have it is how it should be?
one note is that the gear changes are quite hard at the moment, near impossible. granted, there's no oil in the gearbox.. just mentioning this
incase it would be resolved if the gearbox was mounted below which might align the clutch and gearstick better...
bob
| posted on 3/10/07 at 07:51 PM |
IS the clutch cable and pedal fitted and working ?
Box if bolted to the engine block is as much as you can do, i wouldnt thik the angle would make a difference to the gear selection.
jimbona2
| posted on 3/10/07 at 07:57 PM |
photo attached. clutch cable fittered
