jimbona2
posted on 5/10/07 at 11:10 AM |
cooliant piping thoughts
any opinions on how best to connect the circled areas? I must say there's no room from the radiator highlighted area!!
Avoneer
posted on 5/10/07 at 11:18 AM |
Can you do it in copper pipe?
What size are the outlets?
Pat...
will121
posted on 5/10/07 at 11:44 AM |
alternativly if 32mm outlets, can you get a 28mm copper elbow joined with a short piece of hose then flexible pipe to connect the two. i recently
brought some flexible coolant hose from CarBuilderSolutions which was a good price but may not be as flexible as more expensive silocon hose
Dusty
posted on 5/10/07 at 05:11 PM |
I used 28mm copper pipe. The soldered connectors boost it up to 32 for the points where it joins hose. You can also get 28/16/28 T pieces to plumb in
that heater and bypass hose. You might need to rethink your top hose. Sitting above the exhaust manifold it's going to get a bit warm!
