Author: Subject: hydraulic clutch ?
nathanharris1987
posted on 11/10/07 at 09:40 AM Reply With Quote
hydraulic clutch ?
Just saw jollygreengiant posting about him fitting his and its sparked curiosity!
What’s the benefit of fitting a hydraulic clutch? Is there much cost to buying one? And is the conversion relatively easy to do if you wanted to install one further down the line?
Nath
ditchlewis
posted on 11/10/07 at 09:42 AM Reply With Quote
i was thinking that too a neat idea.
what combination is he using, a type 9?
ditch
nathanharris1987
posted on 11/10/07 at 09:44 AM Reply With Quote
yeh it was, had an input and return line through the bell housing.
posted on 11/10/07 at 09:48 AM Reply With Quote
I asked the very same question a while back...
http://www.locostbuilders.co.uk/viewthread.php?tid=74879
I like the idea of fitting one, but with the car fully built and on the road with a cabled clutch that works well I can't be arsed though.
ed_crouch
posted on 11/10/07 at 03:45 PM Reply With Quote
I got a concentric system from Burtons on a Vixen. 'spensive, but damned good.
about 200 quid or so for the parts.
you need the hydraulic nose, a release bearing, a braided line kit, and an adaptor and a gasket.
Take the old nose off the input shaft, and replace with the hydraulic one and adaptor.
Ed.
P.S. Oh yeah, you'd need the appropriate master cyl too!
I-iii-iii-iii-ts ME!
Hurrah.
www.wings-and-wheels.net
jollygreengiant
posted on 11/10/07 at 07:50 PM Reply With Quote
Made a plastic ( from the remnants of the instrument binnacle ) plate ( bolt on ) for the supply hose to go through and carefully drilled a 16 mm hole in the top of the bell housing for the bleed hose to go through. Job Done.
Oh yes. Burtons, just under £200.
