donut
| posted on 11/10/07 at 05:39 PM |
Where's me engine number?
Ok looks like someone has nicked me engine number or i'm going blind...again!
Where is it suposed to be and if i ain't got one what can i do about it?
Image deleted by owner
[img][/img]
nib1980
| posted on 11/10/07 at 05:45 PM |
supposed to be at "B" looks ground off to me
donut
| posted on 11/10/07 at 05:47 PM |
I cleaned it up to see if there was a number there but alas nowt
So what can i do?
nib1980
| posted on 11/10/07 at 05:49 PM |
So what can i do?
very little, but with out a V5 It'll be on a "Q" plate anyway.
donut
| posted on 11/10/07 at 06:11 PM |
But i will need an engine number though.
How do i get one or can i make it up
Confused but excited.
| posted on 11/10/07 at 06:17 PM |
IIRC: I believe it may be possible to bring up the ground off number by applying a little acid to the area.
One of the clever lads on here with metallugical knowlege may be of help.
Memo to self; Got to stop watching CSI.
DIY Si
| posted on 11/10/07 at 07:28 PM |
That is true, but I can't quite remember the technique. Basically, a light acid will eat the softer, non punched down metal away quicker than
the stamped bits, so they end up slightly raised. A lamp shone from the side will then help the numbers show up.
Or just go down the local scrappy and 'borrow' a new number.
Actually I thought the car had been in the road? Don't you have the V5 and thus engine number?
Sun Tzu, The Art of War
donut
| posted on 11/10/07 at 09:02 PM |
[deleted!]
[Edited on 12/10/07 by donut]
SeaBass
| posted on 12/10/07 at 07:06 AM |
ROFL & what was you full name and address Andy - just for reference when the police check this forum for the court case...
donut
| posted on 12/10/07 at 07:09 AM |
shhhhhh
Simon
| posted on 13/10/07 at 05:37 PM |
At work we colour the finished bronzes with potash (if that's the colour we want!), and that shows up welds quite clearly. It goes with a wire
brushing though.
Simon
Stoo
| posted on 14/10/07 at 05:23 PM |
Quick question surrounding this - when I swap my Pinto to a Zetec - should I inform the DVLA?
Or keep quiet?
Is there a risk that with the change of engine they will want to inspect the car?
Stoo
bob
| posted on 14/10/07 at 05:36 PM |
I swapped the pinto for a zetec and just informed the DVLA of a new engine number and cc change, no probs there as engines are changed al the time.
Stoo
| posted on 14/10/07 at 06:00 PM |
Sweet thanks - one less thing to worry about.
Stoo
Deckman001
| posted on 14/10/07 at 06:33 PM |
Hi guys, so what was the out come as to having no engine number stamped on the block ??
Jason
donut
| posted on 14/10/07 at 06:50 PM |
1, make one up and hope the SVA man don't care and DVLA accept it
2, Buy a block or get a knackered block of fleabay
3, use the number of another engine that's not going to be used on the road [not recommended for obvious reasons]
Deckman001
| posted on 14/10/07 at 09:47 PM |
I was hoping for using the 'acid type' response
I'll have to re read 'I saw you', is says how to do in the book
Jason
donut
| posted on 14/10/07 at 10:43 PM |
Oh yeah, forgot about that one. I can't see it working to be honest but hey....
