lsdweb
posted on 13/10/07 at 06:08 PM |
Clipping round hose to round tube!
Hi Guys
I've got a 25mm hose that runs parallel to a 25mm chassis member, I'm trying to think of the best way to secure the pipe to the chassis
member. Any thoughts. It needs to ne neat and light! They're within a mill or two from each other.
Wyn
iiyama
posted on 13/10/07 at 06:10 PM |
figure eight with some zip ties?
If its broke, fix it. If it aint broke, take it apart and find out how it works!
NeilP
posted on 13/10/07 at 06:12 PM |
Loose cable tie round the hose - ditto the tube. Third small one to tie them together like handcuffs - Pull this one tight first then tighten the
first two - Gets you as close as the size of the body on the third tie...
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
Mark Allanson
posted on 13/10/07 at 07:03 PM |
Even neater
http://http://www.screwfix.com/app/sfd/cat/pro.jsp;jsessionid=DONDJ2P0HE4BACSTHZOSFFI?id=12293&ts=02111
[Edited on 13/10/07 by Mark Allanson]
Avoneer
posted on 13/10/07 at 07:36 PM |
One tie clip round them both and then one inbetween them pulling the loop tight.
Pat...
lsdweb
posted on 13/10/07 at 10:06 PM |
Thanks guys
I'd thought of the cable tie option but not the tool clip option. I'll probably give both a try!
Wyn
The Great Fandango
posted on 14/10/07 at 10:50 AM |
My experience with cable ties on the chassis has shown that they're bloody good at taking paint and powder coat off.
I'd always wrap some insulation tape around the chassis and apply the cable-tie over the top of it.
Another top tip is to buy the red-handled clippers (called Flush-Cutters) that Mike Brewer uses on his Westfield DVD. They're excellent at
taking the cable tie end off cleanly without leaving dangerous sharp ends that will scratch you.
He Who Dies With The Most Toys Dies The Happiest
Macbeast
posted on 14/10/07 at 02:40 PM |
Double 22mm plumbing clips ?
bob
posted on 14/10/07 at 04:26 PM |
figure 8 with two P clips.
procomp
posted on 15/10/07 at 07:13 AM |
Hi for cutting the cable ties cleanly. Just grind the back face of the cutters flat.
Cheers Matt
