ironside
| posted on 17/10/07 at 03:45 PM |
Type 9 Bellhousing to Crossflow Engine Bolt Sizes
Hi there,
Could someone help me out with bolt sizes (length, width and thread pitch) for bolting the Type 9 bellhousing to a Crossflow engine?
There are two different sizes, I've tried searching here but I couldn't find a complete definitive answer.
4 bolts that are for the holes threaded on the bellhousing side. From searching I believe these are M10 but perhaps not standard thread. I've
got some standard M10 bolts but they don't screw in very far.
The remaining 2 bolts (top ones) are for the holes threaded on the engine side. From searching these could be 3/8" UNC? Is that right? What
length?
The starter motor ones are going to be different than for the Escort gearbox too aren't they . . .
Thanks a lot,
Simon.
snapper
| posted on 17/10/07 at 04:29 PM |
Don't Panic.......
Measure captive holes with a stick, nail, pencil then find bolt that is a few mm shorter any other bolt hole that the bolt sticks out off can be a bit
longer.
The starter motor bolts to type 9 will be M10 standard pitch so will the ones that go in the bell housing, I though the Cross flow was metric but if
not then find an imperial bolt that fits then source same thread bolts to the length previouselly measured with stick.
I have a tap & die set with a very usefull thread guage.
I eat to survive
I drink to forget
| posted on 17/10/07 at 05:07 PM |
The crossflow is all UNC - 3/8" in this instance I believe - but wait for confirmation before spending money!
[Edited on 17/10/07 by David Jenkins]
procomp
| posted on 17/10/07 at 05:48 PM |
Hi yep All the bellhousing ones are 10mm metric. And the top 2 that go in to the block are UNC.
Cheers Matt
irvined
| posted on 17/10/07 at 05:59 PM |
The two on the top which bolt into the block are UNC 3/8" - I had to run a tap into mine just to clear out all teh oil and dust and other turd
which had gathered when sitting in the garage for a few years before i could get them in properly.
All the bolts going into the Type 9 are M10.
HTH
http://irvined.blogspot.com
ironside
| posted on 19/10/07 at 11:39 AM |
Thanks a lot for the replies - in case anyone else ends up searching for this in the future sizes I used are:
Top 2: 2x 3/8" UNC x 1.25" long
Other 7: M10 x 40mm long
(4 for the engine and bellhousing and 3 for the starter motor)
