Author: Subject: How long before the fan should kick in
RichardK
posted on 18/10/07 at 03:11 PM Reply With Quote
I've just got to the point of sticking some coolent in my pinto and have run the engine for about 5 minutes at 2000 revs before my bottle went and turned it off.
The fan didn't come in although it's rated at 95 degrees (polo switch)
Any of you pinto lads have a rough idea how long yours takes before the fan kicks in, haven't got my dash on yet so know the temp.
Or is there any other way of accuratly sensing water temp.
Cheers Rich
Gallery updated 11/01/2011
cadebytiger
posted on 18/10/07 at 03:14 PM Reply With Quote
don't think you have a problem there.mine takes a little while to get up to that sort of temperature.
whitestu
posted on 18/10/07 at 03:30 PM Reply With Quote
Its a different engine, but my CVH would run for 20-30 mins after starting up before the fan came on.
Stu
posted on 18/10/07 at 03:34 PM Reply With Quote
As much as 30 minutes --- even longer if you don't have a thermostat.
RichardK
posted on 18/10/07 at 03:51 PM Reply With Quote
This is how I've plumbed it in:-
20mins, that puts my mind at rest
Any problems? Pipe goes from top of water pump to bottom of expansion bottle, smaller pipe goes from top of expansion bottle to top of thermostat housing take off. Used metal pipe across exhaust headers just in case! Although it is quite a way off.
Rich
posted on 18/10/07 at 04:11 PM Reply With Quote
A pyrometer (IR thermometer) is a useful piece of kit for this kind of situation. It'll give you a nice reading for the radiator hose to show approx what temp the coolant is currently at.
Also useful for checking headers when there's a misfire, checking tyre temperatures etc etc....
Not that expensive nowadays either....
stevec
posted on 18/10/07 at 04:19 PM Reply With Quote
Looks like your thermo switch is at the bottom/colder side of the rad so it may take a while to cut in. And that looks a very big rad.
Steve,
[Edited on 18/10/07 by stevec]
