Author: Subject: Which coil pack?
emsfactory
posted on 19/10/07 at 03:36 PM Reply With Quote
Which coil pack?
Can you use a coilpack from a 1994 2ltr zetec for a megajolt install?
Any pros or cons?
paulf
posted on 19/10/07 at 04:22 PM Reply With Quote
Yes all ford 4 cylinder coilpacks are the same.
Paul.
emsfactory
posted on 19/10/07 at 04:45 PM Reply With Quote
Good stuff. Cheers Paul.
I am gearing up to start the install so expect some more questions soon
posted on 19/10/07 at 04:56 PM Reply With Quote
They are electrically similar, but there are at least two different designs, with differing connectors for the HT and LT cables.
emsfactory
posted on 19/10/07 at 07:50 PM Reply With Quote
Does that matter if I buy the leads to suit later? Is one style harder to get or more expensive?
paulf
posted on 19/10/07 at 07:54 PM Reply With Quote
The main difference is that the early ones have a sort of clip on the plug leads to the coil, the later ones are just push in like an old style dizzy and seem like a cost cutting exercise by ford to me as I prefer the earlier type of plug lead fitting.
As far as i know the LT conection is the same on both.
Paul.
major
posted on 21/10/07 at 09:47 AM Reply With Quote
Direct coil instalation or edis 4?
emsfactory
posted on 24/10/07 at 10:08 AM Reply With Quote
edis 4
major
posted on 29/10/07 at 11:50 AM Reply With Quote
good choice, and yes U can use the coilpack.
