Author: Subject: brown trousers moment!
2b_pablo
posted on 28/10/07 at 09:26 PM Reply With Quote
driving up an offramp on local motorway when hell erupted in my transmission tunnel. seems my prop had a rubber donut which at that moment disintegrated.
tunnel got pounded until i got stopped and was very lucky it didnt come through and mangle my leg!
ripped a hole in the floor pan tho.
so obviously I wont be refitting a prop donut so can anyone tell me what I need to be fitting as a propshaft? All sierra gear with T9 box.
just as I was selling up to buy a BEC too
posted on 28/10/07 at 09:30 PM Reply With Quote
Get a decent prop company to make one for you . Bailey Morris in Eaton Socon near St Neots are very good.
blakep82
posted on 28/10/07 at 09:35 PM Reply With Quote
and while you're at it, convert to BEC if thats what you want to do!
________________________
Avoneer
posted on 28/10/07 at 09:42 PM Reply With Quote
I've got a nice prop you can have for free (it's got a car attached to the rest of it though).
Pat ;-)
cerbera
posted on 28/10/07 at 10:13 PM Reply With Quote
Pat ;-)
lol. Nice sales pitch!
blakep82
posted on 28/10/07 at 10:15 PM Reply With Quote
Pat ;-)
he's been trying that one all day! tried it with a english axle too! can't even give the car away! lol
cerbera
posted on 28/10/07 at 10:23 PM Reply With Quote
If we is givin it away....... Me will have it
geoff shep
posted on 28/10/07 at 10:55 PM Reply With Quote
You can get a propshaft made up with a UJ in place of the donut (which was more of a shock absorber than a UJ in the original Sierra fit). RH used to do one to fit using your supplied front and back ends - not sure if present company do the same but plenty of other suppliers. Good job its got a thick tunnel wall not alloy sheet.
westcost1
posted on 29/10/07 at 10:44 AM Reply With Quote
Im going to fit a prop retaining band bit of flat section bent to form a U shape and bolted through the floor this keeps it from flapping about if it all gose wrong. my brothers boss has one fitted to his race cobra.
Vindi_andy
posted on 29/10/07 at 12:14 PM Reply With Quote
I thought the rubber donut was on the MT75 on the higher spec sierras as was previously mentioned to ease the power take up
2b_pablo
posted on 29/10/07 at 01:33 PM Reply With Quote
cracking idea mate!
2b_pablo
posted on 4/11/07 at 09:57 AM Reply With Quote
pics added - was nasty one alright!
blakep82
posted on 4/11/07 at 01:00 PM Reply With Quote
ooooh, close to taking out a brake line too
2b_pablo
posted on 4/11/07 at 01:51 PM Reply With Quote
guess whats being rerouted
posted on 4/11/07 at 04:58 PM Reply With Quote
Yep, the device fitted to the sierra propshaft is simply a cush drive to asborb any vibration. It has no capacity to absorb any angular movement of the proshaft, and in fact has a pin that fits into the splined section to prevent any movement. It must be used with a UJ at each end of the prop, or preferably thrown in the bin.
Bob C
posted on 4/11/07 at 05:32 PM Reply With Quote
The pin actually goes into a spherical bearing to allow angular movement.
Note that an almost identically similar joint was used in the driveshafts of quite a lot of cars with IRS (imp, original elan, GT6) so they can take a) a lot of torque and b) up to nearly 20 degrees (I had an elan.......).
In the particular application above it looks as though too much of the spline was used, i.e. the prop was rather shorter than it should have been, so the gearbox part of the joint was able to move over an inch away & defeat the failsafe centre pin. I'd also suspect it had been on the way out for quite some time! Regardless, it must have been a very unpleasant experience!
Bob
2b_pablo
posted on 4/11/07 at 07:47 PM Reply With Quote
my m3 had one (rubber donut) so it cant be that bad, prob as old as the donor tho lol 20yrs
posted on 4/11/07 at 10:16 PM Reply With Quote
Ahh, mine must have been seized solid because I couldn't get it to move at all. Crappy thing anyway that have no place on a 7.
