Author: Subject: 95 Zetec - bike carbs or injection SVA?
mikeb
posted on 6/11/07 at 11:32 PM Reply With Quote
I have just bought a 95 sliver top zetec.
Bike carbs seems the cheapest way to get this running but I'm sure I remember reading somewhere that you can't get carbs through the emissions test at SVA?
i need advice on where to go from here locost is definately required!
Mike
Paul TigerB6
posted on 7/11/07 at 08:43 AM Reply With Quote
Do you know what month the engine is from as the SVA requirements are much tougher for August 95 engines onwards. You will need a Cat for the later engines but may well be ok with bike carbs anyway if they are set up properly.
posted on 7/11/07 at 08:48 AM Reply With Quote
Pre August 95 is OK with bike carbs.
My 1.8 zetec was from a 95 N reg Escort and when I sent the engine number to Ford they gave the date as Feb 95 which was earlier than the reg date.
After 08-95 you need a cat.......
mikeb
posted on 7/11/07 at 11:39 PM Reply With Quote
Just checked my engine number looks like its has SS which according to zetec-cat.co.uk should be July 95! Could just be in by one month. How did you go to at FORD to get a verification of the date. If it is ok I'll go bike carbs and megajolt an no CAT, would be nice to have a bit of luck!
Mike
Paul TigerB6
posted on 8/11/07 at 10:04 AM Reply With Quote
Info is on the same site there. When i sent mine off (8 years ago!!!), i didnt send it to anyone in particular - just the department at the address below.
Quote "For SVA purposes, you will require written proof of the date of engine manufacture. To obtain this, either send a letter or a fax, including the engine type and engine number to the Ford Technical Information Centre at the following address:
Ford Motor Company
PO Box 300
Walsall
WS5 4QH
Fax: 01922 725 266 "
