locoboy
| posted on 12/11/07 at 09:13 PM |
Pinto sump chopping
Hi i have 2 spare pinto sumps in the garage that im going to chop down and sell on.
Im not planning on making extra wings for it to retain the same oil capacity, i know plenty have not done this with no ill effects.
So how much have you chopped it by?
Locoboy
snapper
| posted on 12/11/07 at 09:43 PM |
shorten a Pinto sump
This how the RHOCaR boys do it.
Others have added volume to the rear, only usefull if you dont have any chassis cross members to miss.
[Edited on 12/11/07 by snapper]
I eat to survive
I drink to forget
mitch2b
posted on 12/11/07 at 10:48 PM |
you beat me to it Paul
locoboy
| posted on 13/11/07 at 07:22 AM |
Cheers fellas.
Locoboy
DarrenW
| posted on 13/11/07 at 09:35 AM |
Rather than put a wing on the side i extended the sump forward and plated the lower section with 3mm steel. I also angled this up at the front to act
as a mini skid plate.
The bit chopped off was inverted and welded back in to act as a bit of a baffle and keep oil around the pick up pipe. I recently posted some pics in
an oil breathing post. Also try searching for same mods under Mark Allanson's name - i followed one of his excellent guides.
