| posted on 13/11/07 at 02:38 PM |
TB power
anyone have Throttle Bodiy data for how many car engine bhp they can provide?
(specifically interested in Kawasaki ZX6R, and Suzuki GSZR 5750)
(I've read somewhere 600 TB can go up to 200 bhp and 1,00 go to 300 bhp !!)
ned
| posted on 13/11/07 at 02:56 PM |
You want to look at the injector flow rate and inlet size/how muchthey can flow. This will be far more acurate than someone coming up with a pub bhp
figure imho as it will depend on the engine and other tuning bits on it etc.
Ned.
beware, I've got yellow skin
| posted on 13/11/07 at 04:54 PM |
thanks but no helpy, linky no worky
| posted on 13/11/07 at 05:46 PM |
quote: Make/Model: ZX6R 636 B1
Year: 2003
Number of Tb: 2
Inside Diameter: 38mm
Center-Center (left to right from behind): 75-75-75mm
Overall Length: 90mm
Outside Diameter (intake): 52,6mm
Outside Diameter (filter): 50,8mm
Separate casting: No (dual Tb´s)
Injector Make/Model: BOSCH 280031V
Flow Rate (45psi/100%): 245cc/min
flow rate - is that saying max flow rate is 245 cc per min?
is that each per injector?
let's do quick sum.
most extreme mpg = 10 @ 60 mph so that is 6 gallons per hour or 450 cc per min.
If the above flow rate num ber is per injector, then there is plenty to spare.
Even at 20 mpg there is a little bit to spare assuming 245 is total flow rate.
| posted on 13/11/07 at 07:25 PM |
let's do quick sum.
You can't really go by mpg, i.e. would you need bigger injectors if you drove around in 1st and 2nd gear a lot?
If you know what sort of power you are aiming for, then you can use one of the injector flow calculators on the web, though they tend to be quite
pessimistic i.e. calculate larger injectors than you actually need.
http://www.witchhunter.com/injectorcalc1.php4
If the power you are aiming for is less, or not much more than the bike that TB's came from then you should be in good shape.
[Edited on 13/11/07 by MikeRJ]
| posted on 14/11/07 at 04:57 PM |
tanks for that;
injector flow rate is: 246.09375 cc/min
so if the spec. above is per injector, then I am right on the button with these TBs.
