| posted on 13/11/07 at 09:43 PM |
Bike fuel pump for a Weber DGV?
I'm trying to plan my change-over to bike carbs, and the first thing I want to do is fit the bike fuel pump.
The question is, will it supply enough volume & pressure to supply the Weber DGV 32/36 down-draft carb I've got at the moment? If it can, I
will be able to do the switch in easy stages, without taking the car off the road for any great length of time.
I can't remember exactly which bike it's off (large Yamaha, I think). Timf - can you remember what it was?
cheers,
RichardK
| posted on 13/11/07 at 09:48 PM |
As dgav webers only need about 3psi I think you may have the opposite problem and may need a fuel regulator if you fit the bike fuel pump. I thought
bike pumps ran alot higher psi than that. Wait to be corrected
Rich
Gallery updated 11/01/2011
Dingz
| posted on 13/11/07 at 11:02 PM |
Volume won't be a problem you will not be using much more, if any, fuel than you do now. Pressure may be a problem, bike carbs only need about 1
psi so it might be a problem. If you have a mechanical pump fitted to your engine why not just use that and drop the pressure with a regulator?
Thats what I use.
