cjtheman
| posted on 21/11/07 at 09:28 PM |
crossflow engine mounts
hi all
i am waiting for the ok to pick up my crossflow engine
and i want to crack on with making the engine mounts does anybody have the dimensions ( height and angle of the tubes )for them just so i dont have to
wait for the engine
cheers
colin
wanted
sunny weather
sva pass 12/6/09
taxed 16/6/09
TGR-ECOSSE
| posted on 21/11/07 at 11:55 PM |
Hi i don't have the measurements for you as the engine with the mountings (luego) is in hibernation for the winter but i can tell you that the
sides are not the same size.
myeates
| posted on 22/11/07 at 12:42 PM |
again dont have tham at hand as away from home but is it a 1.3 or 1.6 i think it makes a difference sorry not to be more help
cjtheman
| posted on 22/11/07 at 05:04 PM |
hi again
its a 1.3 good point
come on people any help???
cheers
colin
wanted
sunny weather
sva pass 12/6/09
taxed 16/6/09
| posted on 22/11/07 at 06:00 PM |
I would say that unless you can find a scrap engine to use, then wait until you get yours. The chances of making a set of mounts that fit perfectly,
set the engine at the correct height and don't foul anything just from some dimensions is slim IMO.
| posted on 22/11/07 at 07:07 PM |
I would suggest that you make the plates that fit onto the engine (I'm sure someone on here could give you the dimensions) and the plates that
fit to the chassis.
Then all you'll have to do is cut and shape the bit of tubing that goes between the two, once you get the engine sitting on blocks in the
chassis.
Michael
| posted on 22/11/07 at 09:55 PM |
Make sure what ever rubber mounts you use are new before making the mounts for the chassis.
I used the ones from the engine, and found I needed to move the ones on the chassis otherwise the engine wouldnt sit down.
