bigandy
| posted on 23/11/07 at 06:07 PM |
Suitable expansion tanks (cooling system)?
Evening folks.
Now I have figured out what sort of expansion/header tank I am after for my car's cooling system, (with thanks to everyone here that helped and
offered advice!) I need to find a suitable tank.
So, can anyone recommend a suitable tank? I am after the following:
- 1 inlet at the top of the tank, size not critical, but around 8mm to 19mm would be good
- 1 outlet towards the bottom of the tank, size as above
- 1 pressure relief cap (radiator cap type thing) at the top of the device, suitable for a toyota 4a-ge engine (so I don't have to fit a
pressure releif device anywhere else in the system)
- Either a see through bottle, and/or a water level sender. Not too bothered about the type, I can work around that
- A mounting method that is easy to incorporate in an engine bay that has 25mm box section as the main structure to fasten it to.
I'm hoping to have a mooch around a scrapyard this weekend, but if anyone has any tips as to what I should look out for, it would be much
appreciated.
I did wonder about getting a custom ally tank made up, but I think I prefer cheap and readily available, over pricey and shiney. Especially when it
will live in the engine bay
Ps. I promise this will be my last query on cooling system stuff, unless I decide to fit an electric waterpump
Dammit! Too many decisions....
Humbug
| posted on 23/11/07 at 06:20 PM |
FWIW I used a Rover 25 expansion tank, mainly because my K series was from a Rover 25 so I figured the hoses should match up!
It's got a top and a bottom hose and a pressure cap, and has marknig on the outside. it is designed to "hang" somehow on the
original - to fit it in my engine bay (after I had fixed other stuff to the scuttle...) I made a bracket to suit from ali.. Pic in my archive
called
Metal Hippy
| posted on 23/11/07 at 06:27 PM |
Volkswagen new caddy expansion tank with level probes fitted..
You'll need the cap to fit obviously, the right connector for the probe and a relay from a mark 2 golf for lighting up a bulb in the dash when
the level drops too low..
All that lot for ~£30 brand new and shiney..
I have all the part numbers if interested..
[/works for a VW van centre in the parts department blog]
[Edited on 23/11/07 by Metal Hippy]
Cock off or cock on. You choose.
Ricks-9r
| posted on 23/11/07 at 06:53 PM |
Re- Header Tank
Ive just fitted this ,brought for my R32 but found a use on the Mac#1
(pressed steel bracket now changed for solid alloy one now
it measures approx 60mm x 150mm 4 outlets @ 8mm & comewith tubing & 3 caps (small Jdm type) ,was a pain filling or checking the coolant
without it ,I got it from http://www.driftworks.com/catalog/
on a special offer,wasabout £28 posted if i remember ,give them an email as they dont seem to have any in the shop atm
COREdevelopments
| posted on 23/11/07 at 07:39 PM |
i would use a toyota mr2 roadster type, its clear and has correct pressure relief cap, an outlet and inlet, its what i will be using, or like said a
vw one is ok.
rob
Confused but excited.
| posted on 23/11/07 at 10:39 PM |
Good old ebay. I got a spherical VW/Audi one as fitted in the Audi TT for the princely sum of £0.01+ £2.50 p&p.
DEAN C.
| posted on 26/11/07 at 12:52 AM |
I used the Rover 220gti old type(>95)Also I think that the Rover diesel218/418 Peugeot engined cars might be the same.
If you look in my photo archive you can see it in "beauty and the beast" picture.
Works ok on my 4age.
[Edited on 26/11/07 by DEAN C.]
Once I've finished a project why do I start another?
procomp
| posted on 26/11/07 at 08:50 AM |
Hi the later vectra ones brandnew from the stealer are £9+vat. And come with one or two ( depending on model )8mm returns and the usual 15mm bottom
outlet.
Cheers Matt
[Edited on 28/11/07 by procomp]
