Author: Subject: Bmw Mini Superchargers
stevec
posted on 26/11/07 at 11:05 AM Reply With Quote
What boost pressure do these produce as standard? I mean the bog standard ones not the Cooper upgrades.
Cheers.
Steve.
Ricks-9r
posted on 26/11/07 at 11:28 AM Reply With Quote
http://www.mini2.com/forum/faq.php?faq=faq_performance#faq_faq_tech_details
stevec
posted on 26/11/07 at 11:40 AM Reply With Quote
Nice one.
Steve.
posted on 26/11/07 at 11:41 AM Reply With Quote
Cheers.
Steve.
0.8 bar when fitted to the 1.6 MINI engine, but obviously if fitted to a different engine the boost will depend totally on the engines displacement and pulley ratio.
posted on 26/11/07 at 12:27 PM Reply With Quote
It depends on how fast you spin them
Bear in mind the Rootes type blower is relatively inefficient (even with PTFE blades and close tolerances) but has the advantage that it produces power in a linear manner.
So going for crazy power increases isn't that sensible. If you're going to produce big power you might be better off with a Centrifugal blower.
Then again you also have to bear in mind that the Mini S engine is a 1.6. If you supercharge a BEC the engine will likely be smaller, therefore giving a higher boost for the same amount of supercharger rotation (and hence heat)... Then again, you also have to bear in mind other factors that determine how much boost you'll get at a certain blower speed like cam profile, timing etc etc....
Werner Van Loock
posted on 26/11/07 at 03:39 PM Reply With Quote
thomas4age on here is putting 2 on a 4ltr Lexus V8 and did some calculations. Send him a u2u
http://www.clubstylus.be
iank
posted on 26/11/07 at 07:48 PM Reply With Quote
IIRC MINI superchargers are basically Eaton 45's with slightly different packaging.
Here is the Eaton technical page linky
Anonymous
oadamo
posted on 26/11/07 at 08:17 PM Reply With Quote
i had one spining out 1 bar boost the pic of the charger is in my archive. it went very well but couldnt give me much up the revs so i changed to a turbo.that was on a 1.6 low comp engine.
adam
thomas4age
posted on 29/11/07 at 10:18 AM Reply With Quote
Hey hello
Quite right about the boost deliverance on an different engine. you cannot calculate anything in detail unless you know the total airflow of the engine in the rev range.
you can however take the stock SC'd engines vallues, calculate NA out of that then calculate the NA power per cc of your engine and multiply that by the power difference of the original NA vs Blown you'd get a pretty good figure of what will be happening. that's power difference.
for boost ratio take displacement vs pully sizes and cross multiply that with the to be set-up, aslo a rough figure but at least you'll have somthing to work with
I plan to keep the original pulleys on both the engine and both compressors, that way the chargers will be running out of revs somewhere around 6800rpm (max rev for the cooperS M45 is 14.000 according to eaton)
You can however go way beyond that if the intercooling is good 15 should be doable and I know a few that do 17500rpm.
take into acount that the power up top may not be all that fancy compared to turbo's, but the torque from no revs at all is also very usefull if you can get it down.
the mini crew are complaining a lot about the top end, but that's not a shortcomming of the M45 but a short comming in the intercooling system.
go for it they're cheapas chips.
Just one thing make sure you have the piece of intake tract from the throttle valve to the supercharger entry, those are a nightmare to locate.
I still need two of those BTW so if you have any lying around please contact me.
this one
intake pipe cooperS. needed.
planning of, 1uzfe 4L Qcam 32v V8 Lexus Twin M45 charged, 380cc injectors laminova intercoolers, omex 710 ecu.
anywhere inbetween 350-450hp at the wheels. stock engine hardware all the way. charger pully's might be changed in time. but intercooling is key, and laminova is very good at just that
Grtz Thomas
[Edited on 29/11/07 by thomas4age]
If Lucas made guns, Wars wouldn't start either.
