| posted on 6/12/07 at 04:19 PM |
Rubber mounts for fuel pump?
I will shortly be fitting an ex-bike fuel pump to my car.
Should I use rubber mounts for this, or will direct 'hard' mounting be OK?
I was just wondering if there's some technical reason for doing it? I don't reckon I'll be too bothered by either the noise or the
vibration of the pump - certainly not when I'm on the move!
Pdlewis
| posted on 6/12/07 at 04:22 PM |
I mounted an R1 pump on mine and used the original rubber mounting point, if you could get hold of one they are ideal
bob
| posted on 6/12/07 at 04:26 PM |
Yup i used the original rubber mounting on my R1 pump too, the mount wraps around the pump and has an ear with an M8 hole in for mounting.
| posted on 6/12/07 at 07:01 PM |
Mine's from a Yamaha FJ100 or 1200!
Danozeman
| posted on 6/12/07 at 07:15 PM |
My r1 pump is using the original rubber mount too. Its best to rubber mount it to stop vibrations interfering with it.
YOu could make a bracket and use a rubber bobbin??
Dan
| posted on 6/12/07 at 08:59 PM |
I may be OK - I had a good look at it tonight, and it's got 2 rubber bits in the mounting. The first is a sheet of ribbed rubber wrapped around
the casing, with a steel band around that. The band has a flange with one rubber mount and a spigot. My guess is that the spigot goes through
another rubber mount, with the whole lot clamped in with a nut and bolt through the first mounting.
...or something like that!
