Gaz 1977
posted on 15/12/07 at 10:52 AM |
ford gearbox suggestions
I am now looking for a gearbox to fit to my zetec. i dont really want to go the scrapyard root, but i dont want to spend a fortune, I have heard that
first on a type 9 is a little too short.
Can anyone help
Thanks, Gaz
zilspeed
posted on 15/12/07 at 11:23 AM |
It is indeed.
Mor specifically, it is the gap between 1st and 2nd that is the big issue. That's why people like BGH Geartech do a long first gear set.
Conversely, my old xflow gearbox has a much closer 1st - 2nd gap, and I reckon I can live without a 5th gear, so may leave it in.
[Edited on 15/12/07 by zilspeed]
posted on 15/12/07 at 11:38 AM |
Gaz,
As you know, I've been considering this - for me, the issue is that the engine runs out of revs at around 25mph. The rest of the gears are fine,
so a higher ratio diff won't help.
BGH prices are 'competitive', i.e. cheaper than Quaife, but still a fair amount of cash - not much change out of £300 for a gear kit (and
you'll still want gaskets, seals, etc on top of that) or not much change out of £500 for a fully refurbished and guaranteed exchange box. The
refurb box sounds a lot, but when you add up all the extras it's not much dearer than the gear kit. The main gain is that 1st would be good for
40+ mph, which is a significant difference. Note: these prices are for the 'up to 145BHP' stuff - higher-power stuff is a fair bit more
expensive.
I'm holding off for the moment as I'm concentrating on the bike carb installation. I rarely use 1st once I'm rolling, so for me the
gains would be small in comparison with the amount of cash required.
cheers,
Paul TigerB6
posted on 15/12/07 at 11:44 AM |
You might do well looking into fitting a Capri 2.8i box then. Dont have the details but i believe the main shaft needs modifying (shortening??) to
allow it to fit. Worth a search on here anyway for more info - or i'm sure someone will know anyway.
Keep an eye on ebay for a Tran-x or Quaiffe type 9 box also
snapper
posted on 15/12/07 at 12:05 PM |
The solution for fitting the V6 box to a straight 4 engine is to fit the 30mm Caterham gearbox spacer between the Type 9 V6 box and the straight 4
bell housing then the longer QH133 (8mm thicker) clutch release bearing.
If you fit this first then no problems b ut if you retro fit as i have then the gearbox goes back 30mm with a shorter prop or the engine goes forward
30mm with associated engine mount and exhaust location moving forward as well.
The better first (3.36) will allow close to 35 mph with a 3.9 diff and over 60 in second (1.81)
[Edited on 15/12/07 by snapper]
I eat to survive
I drink to forget
snapper
posted on 15/12/07 at 12:18 PM |
V6 box, spacer and RS2000 bell housing
I eat to survive
I drink to forget
snapper
posted on 15/12/07 at 12:19 PM |
Spacer
I eat to survive
I drink to forget
snapper
posted on 15/12/07 at 12:29 PM |
i have attach an excel gear speed calculator
I eat to survive
I drink to forget
Mark Allanson
posted on 15/12/07 at 12:49 PM |
I recognise that!!
posted on 17/12/07 at 01:14 PM |
Aim for the old 2000e ratios for the lower gears --- istr the V6 type 9 box is quite close to this.
Gaz 1977
posted on 19/12/07 at 07:34 PM |
thanks chaps, it is great to have a few ideas.
i will get xmas out the way then i will go shopping.
do you think i can get one in the sales
