Author: Subject: Stronger Zetec Clutch?
djtom
posted on 18/12/07 at 01:49 PM Reply With Quote
Having found out on a Bedford Autodrome trackday that my distinctly second hand 1.8 Mondeo clutch didn't much like 220-ish bhp and 200-ish ft-lb (cue clutch smoke, rev limiter and horrid smell), I'm on the lookout for a stronger clutch to put into the firing line.
I'm using a 1.8l Zetec flywheel, so I need a 220mm clutch. Supposedly an Escort RS Turbo clutch will fit, but I'm not sure if these can handle more power than the mondeo ones.
As far as I can see my options are as follows:
New Mondeo clutch
New Escort RS Turbo clutch
Expensive paddle clutch that's horrible in traffic
Hideously expensive multi disc clutch
Is there a clutch from a diesel that will fit?
Are there any other options like an uprated cover plate or friction disc? Should you replace both at once?
Any recommendations welcome.
I don't want to spend a fortune, as the gearbox will probably explode next. Type 9 vs 220bhp is only going to end one way....
Tom
Volvorsport
posted on 18/12/07 at 02:25 PM Reply With Quote
keep the clutch as the weak link , or upgrade the box . or fit a t5 box .
paddle clutches/ multi plate ones arent as expensive as you might think , especially when you have to buy an uprated clutch pressure plate , and driven plate .
bar the flyhweel machining for sach single plate 200mm clutch with organic material ie user friendly and sprung centres .they run about £350 +vat , and can handle 365 nm or 510 with a sintered plate .
considering juat a cover is £180 + , then a driven plate to match at around teh same price - it becomes entirely possible .
Of course if an ST24 clutch fits or something then id expect that to be the choice .
www.dbsmotorsport.co.uk
getting dirty under a bus
garage19
posted on 18/12/07 at 02:49 PM Reply With Quote
The rs turbo clutch is the same part as the 1800 diesel clutch.
Duncan_P
posted on 18/12/07 at 04:15 PM Reply With Quote
Had a quick look and most of the clutches for the high powered fords seems to be 240mm i.e. ST24, Cossies etc
Not vastly helpful i know. But if you switched to a larger flywheel then you would have more choice of standard clutches that could take the power.
Dusty
posted on 18/12/07 at 06:03 PM Reply With Quote
Redrilling the 1800 flywheel for a pinto clutch with uprated conventional pressure plate and organic driven plate seems a common fix.
scotty g
posted on 20/12/07 at 05:26 PM Reply With Quote
Anyone know what the part number is ?
scotty g
djtom
posted on 22/12/07 at 01:56 PM Reply With Quote
Hmm, tempted to go for a cheapy Escort diesel clutch for the time being, as cash is a bit tight at the moment. Seeing as you can pick up a clutch kit on ebay for £30, it might be ok for a while. I have a feeling that the Mondeo clutch already had 70k of wear, and according to the RS Tubo forums the escort clutch is ok up to about 200bhp. Driving a car of half the weight it should hopefully cope with my abuse!
Regarding drilling the flywheel for a pinto clutch, who can do this and for how much?
I guess the other alternative is to use the 2.0l flywheel with a 240mm clutch, but the 2.0l flywheel is a heavy old thing....
Sadly, there are few options for uprating the gearbox other than stronger internals for the type 9, as the Super Six is very narrow and MT75 or T5 boxes supposedly won't fit in the tunnel :-(
Tom
scotty g
posted on 22/12/07 at 03:36 PM Reply With Quote
plenty of people run well over 200bhp through their T9s without any issues.
Isn't the 1.8 zetec flywheel thinner than the 2 litre one?
