Author: Subject: changing 45s from XE to pinto?
2b_pablo
posted on 18/12/07 at 04:28 PM Reply With Quote
hi all, Im buying some 45 dellortos from a vaux XE install and wondered what I need to do to make them run on my pinto?
obviously the manifold is different but any ideas what jets etc I need to get and how I can get it running enough to get it down to a tuner to set up for me?
cheers.
ditchlewis
posted on 18/12/07 at 04:39 PM Reply With Quote
this is a document i have found interesting. i found it on the net some time ago when i was trying to understand how they worked.
this is not my work, the guys name is Dave Andrews. it might give you a good idea of what you need.
ditch
[Edited on 18/12/07 by ditchlewis]
matt_claydon
posted on 18/12/07 at 04:58 PM Reply With Quote
They should run well enough to get to a tuner if they were set up properly for the XE.
2b_pablo
posted on 18/12/07 at 05:01 PM Reply With Quote
ditch
interesting reading that. thanks!
2b_pablo
posted on 18/12/07 at 05:02 PM Reply With Quote
not so bad then cheers
Fatgadget
^^^ As above.Just nurse it to your nearest Rolling Road and get it re jetted there once and for all.
posted on 18/12/07 at 05:10 PM Reply With Quote
DCOEs are quite tolerant of incorrect jetting IME; even with jetting that is quite a long way out you can generally get an engine to run, if somewhat roughly.
