gy351100
| posted on 19/12/07 at 05:04 PM |
type 9 speedo
hi there
did ford ever fit an electric/electronic speedo drive to the type 9
if so which model car was it fitted to
cheers
keith
martin1973
| posted on 19/12/07 at 05:09 PM |
just sold a type9 which appeared to have both cable and eletronic ?
was in a 1.6 lx 1991
martin
mcerd1
| posted on 19/12/07 at 05:12 PM |
mainly later models with EFI engines I think, just before they changed to MT75 boxes
both my F reg Granada's have it (2.0 EFI Pinto's)
gy351100
| posted on 19/12/07 at 05:14 PM |
type 9 speedo
hi martin
excuse my ignorance
which model 1.6 lx are you refering to
cheers
keith
martin1973
| posted on 19/12/07 at 06:00 PM |
sorry should have said sierra 1.6 lx
martin
bonzoronnie
| posted on 19/12/07 at 06:27 PM |
Electric speedo
I think you may find that the electrical terminal was in fact the reverse light switch.
To my knowledge, Ford never fitted an electric speedo to the Sierra type 9 gearbox.
Ronnie
[Edited on 19/12/07 by bonzoronnie]
| posted on 19/12/07 at 08:04 PM |
We got a type 9 out of a Granada with an electronic speedometer sender fitted, no cable provision on it though.
Dusty
| posted on 19/12/07 at 09:50 PM |
2.3 Granada has the inductive pickup on a type 9 with the correct bellhousing/input shaft and the bigger grandads also have the pickup but are not a
bolt in fit. No reason you can't swop the pickup onto your current type nine box if you have access to the top of the extension through the side
of the tunnel. If you consider the mechanical drive to be at 5 o'clock on the extension, the inductive pickup bolts on opposite it at 11
o'clock
