rayroni
| posted on 20/12/07 at 08:19 AM |
1.4 16V Ecotec - Water Pump Alignment
Can anybody help me understand where the alignment marks are on the above mentioned engine/water pump, because I can't see any and am completely
baffled. I believe it is the same one fitted to 1.6 also.
Haynes manual mentions them but no picture, Vauxhall 'TIS' even gives a couple of illustrations but still doesn't make sense.
Any advice gratefully received, and if anyone has any pictures that would be fantastic.
Cheers, Andy
Mr Whippy
| posted on 20/12/07 at 08:33 AM |
I'm sure I've worked on the ecotec before, don't you just rotate the pump till the belts the right tension? I think there is a
specified defection in the manual and don't remember using any marks. Something like 30 degs possible twist in the centre.
Mr Whippy
| posted on 20/12/07 at 08:40 AM |
actually this is a better link, about half way down they start going on about the pump
http://www.diynot.com/forums/viewtopic.php?t=80180
rayroni
| posted on 20/12/07 at 09:14 AM |
Thanks for the prompt reply.
All the documentation I have states that you adjust the cambelt tension, by the tensioner and to do this the water pump must be in its correct
location (if only I knew what it was). This is also mentioned in the link you posted. I have not seen any mention of cambelt deflection
'value'.
Unfortunatly in my haste to remove the orginal I forgot to put any markings on.
Mr Whippy
| posted on 20/12/07 at 10:17 AM |
you'll have to clean it down really well, the mark may be the size of nothing, most likey a punched dot.
drawing a blank from the web
