Author: Subject: Electronic gear shift in a CEC?
tegwin
posted on 23/12/07 at 10:49 AM Reply With Quote
Was lying in bed thismorning building my dream car in my head...(as you do!)...
And I was wondering.....assuming that on a transverse engine to change gear you simply have to pull the gear selector rod in and out of the box the correct amount to get each gear...
Would it theoretically be possible to use an electronic system perhaps using Pneumatics and microswitches to have an electronicly controled gear change using paddles on the dashboard?
I can easily design the electronics/mechanicals of the system, im just wondering if I might run into any problems etc?
snapper
posted on 23/12/07 at 10:51 AM Reply With Quote
search for Trickshifter.
See here, i'v done it for you.
Trickshifter, will keep looking as i have seen it someware
OOps this is clutchless manual shift system
Found it HERE
[Edited on 23/12/07 by snapper]
I eat to survive
I drink to forget
Aico
posted on 23/12/07 at 10:57 AM Reply With Quote
You still need to use the clutch.
tegwin
posted on 23/12/07 at 10:58 AM Reply With Quote
Yup, I know I will still need to use the clutch...
The electronic system was just a way of removing the need for a complex rod linkage type gear system....With the engine in the middle, making a decent rod gearchange system seems tricky..
snapper
posted on 23/12/07 at 11:01 AM Reply With Quote
Not with the second link and the trick shift electronics.
Have seen some fully electronic ones in some of the kit car mags recently.
Now if you linked that in to the shift light system with a rev attenuator for the first couple of gears you could make a drag race auto max revs gearshift system.
Just plant your foot and go.
I eat to survive
I drink to forget
snapper
posted on 23/12/07 at 11:06 AM Reply With Quote
Demont Tweeks if your pocket is deep enough
Omex
I eat to survive
I drink to forget
mark chandler
posted on 23/12/07 at 11:21 AM Reply With Quote
Bowden cables for the gear shift, save yourself a fortune.
Regards Mark
posted on 23/12/07 at 11:43 AM Reply With Quote
Regards Mark
With the bonus that you can actually feel the gear change. A hydraulic/pneumatic/electric system will just push the gear lever with no mechanical sympathy, which will end in tears if the box doesn't want to go into gear for whatever reason.
Mr Whippy
posted on 23/12/07 at 12:28 PM Reply With Quote
I've been spending quite a bit of time on this problem. I've been looking at miniature hydraulic cylinders to move the lever. A very simple diagram below -
you can see that any movement at the shifter will be replicated at the gearbox, including the 'feel' of changing gear. Due to the strength of the hydraulic systems very small cylinders could be used.
[Edited on 23/12/07 by Mr Whippy] Rescued attachment untitled.JPG
posted on 23/12/07 at 02:54 PM Reply With Quote
If using single acting rather than double acting, you'd have to be careful to size the cylinders to ensure you don't start creating vacuum pockets etc.
Mr Whippy
posted on 23/12/07 at 03:58 PM Reply With Quote
yeah don't take the diagram to literally, I knocked it together so I didn't have to type so much
Double acting of course and you'll note the pipes are on the wrong ends, but you get the general idea...
