Author: Subject: My 2ltr Pinto alternator wont fit!!
mattgriffiths2002
posted on 28/12/07 at 12:27 PM Reply With Quote
Hi guys,
Having a problem trying to fit my alternator inside the chassis. My engine is mounted a bit further forwards than it should be so that doesnt help either. Nevertheless, has anyone else had this problem and if so, how did you get around it?
One potential solution I have it to buy a smaller alternator and make a new mounting bracket and make it so the alternator would sit much higher almost above or in line with the top chassis rail?
Suggestions appreciated,
Thanks,
Matt
posted on 28/12/07 at 12:28 PM Reply With Quote
I think often people fit a smaller alternator like the nippon denso jobbies. Very small and still produce a fair amount of wallop. As found on many japanese small cars in the scrapyard...
mattgriffiths2002
posted on 28/12/07 at 12:34 PM Reply With Quote
Thanks for that, what smaller alternators could you suggest then as well as that one which would work?
Thanks,
Matt
The Baron
posted on 28/12/07 at 12:48 PM Reply With Quote
I've got a 1.6 pinto & had the same problem. I then fitted a small alternator from a Nissan Micra.
You will need to make a new mounting bracket, and a tensioner. But thats not hard after makng a chassis.
The Baron
bonzoronnie
posted on 28/12/07 at 01:01 PM Reply With Quote
Small alernator
Nissan Micra seems to be the one of choice.
Any compact alternator should be up to the job.
Ronnie
mattgriffiths2002
posted on 28/12/07 at 01:29 PM Reply With Quote
Cheers guys, ill get on with sorting the problem!
Macbeast
posted on 28/12/07 at 02:28 PM Reply With Quote
Bedford Rascal / Suzuki Supercarry has also been suggested
Mark Allanson
posted on 28/12/07 at 03:52 PM Reply With Quote
I have a Kia Pride one on my Pinto
ditchlewis
posted on 28/12/07 at 04:40 PM Reply With Quote
i've used a 1991 nissan micra alternator on a home made bracket which brought it in closer to the block.
alternator £15 inc postage (off ebay) bracket out of 5mm steel plate that i traded. low cost
ditch
Marlon
posted on 28/12/07 at 06:09 PM Reply With Quote
I used a daewoo matiz alt on a home made bracket but i believe that some people have just removed the cooling fan from the pinto alt to give more space. with no problems of overheating because of the low current drain of these cars.
john.
Band Anyone?
Linky to SWMBO 's band
Linky to Brother in laws band
MKoc 1081
