Author: Subject: Gearbox bell housing clearance!
Dave Bailey
posted on 31/12/07 at 05:56 PM Reply With Quote
Need some advice on the minimum clearance I can have between the greabox bell housing and the chassis. Basically it is the amount the engine will move backwards. I am using std engine moount rubbers and the westfield stiff gearbox mounting. I currently have about 8mm clearance
bell housing clearance 1
posted on 31/12/07 at 06:04 PM Reply With Quote
That should be fine, as long as those brake pipes aren't in the gap!
I have just over 5mm gap on my car - never knocked the chassis, even though I have the std Sierra mount.
Dave Bailey
posted on 31/12/07 at 06:16 PM Reply With Quote
Yep! the brake pipes are clear!
thanks
Dave B
posted on 1/1/08 at 11:37 AM Reply With Quote
Fit Land-Rover engine mounting rubbers in place of the ford parts -- stiffer but more or less interchangeable but may need packing plates because they are thinner.
