lid0n
| posted on 2/1/08 at 02:03 PM |
megajolt dcoe tps sensor bracket
does any one have any dimensions/pics that i can use to have one made up?
Paul TigerB6
| posted on 2/1/08 at 03:54 PM |
I have been looking into fitting megajolt to a Pinto myself over the last couple of days and found
this site very helpful. Should give you a few ideas anyway if nobody has proper
dimensions.
wonderfulweasel
| posted on 2/1/08 at 04:24 PM |
I have just finished making and fitting a bracket and TPS to my 45 DCOE. I used the same principal as on the link in the previous reply. I measured
the dimensions myself, but didn't make a note of them (measuring as I made). It's a relatively simple bracket.
Elongating the holes that attach the TPS to the bracket is useful to get a small amount of adjustability of the TPS itself. The TPS holes will also be
dependent on what TPS you use.
I could measure what I did if you are really desperate, but I don't have anything better than a tape measure, so I'm not sure if it would
be sufficiently accurate for you?
