The Doc
| posted on 2/1/08 at 05:08 PM |
What Fuel Pump for twin 40s?
Does the fuel pump have to be red top or similar for these or will a standard pump do the job?
Just that I'm a tight git!
Mike
matt_claydon
| posted on 2/1/08 at 05:14 PM |
My 40s worked fine off the standard Pinto mechanical pump.
SALAD
| posted on 2/1/08 at 05:15 PM |
Anything that is high flowing but low pressure. So you could use an alternative to a Red Top pump in conjunction with a pressure regulator.
Someone will have suggestions for second hand/scrap yard alternatives.
chris taylor
posted on 2/1/08 at 05:17 PM |
Mine also works fine with standard pinto pump, as did my last build,
Chris
The Doc
| posted on 2/1/08 at 05:21 PM |
Anyone find the same result with Xflow?
John Bonnett
| posted on 2/1/08 at 05:32 PM |
I had a 1650 pre-crossflow on twin 40s and initially used the standard mechanical pump. The carbs ran dry after a short full throttle burst. I changed
to a Facet Red Top and Filter King and this arrangement worked perfectly.
John
Fozzie
| posted on 2/1/08 at 07:34 PM |
I have a facet pump (mini electronic).
You do need a regulator. My webers do not like to run at more 3psi.......
Oh I have a 1300 xflow.....
HTH Fozzie
PaulBuz
| posted on 2/1/08 at 08:17 PM |
As Fozzie said, if you fit a facet pump(mines the fast road one) you will need a regulator. My carbs overflow without one
Paul
| posted on 3/1/08 at 11:23 AM |
I'm fuelling twin 40s on 1300 crossflow using enigne pump and don't have any problems.
