Author: Subject: smallest header tank?
Bitten hero
posted on 3/1/08 at 08:50 PM Reply With Quote
Hi all , anybody know of small header tanks that i can use(smaller than the zzr1100 one that is) from whatever ????? cheers gary
mark chandler
posted on 3/1/08 at 09:25 PM Reply With Quote
Contary to popular belief they do not need to be the highest point of the engine as long as the take off point is at the top, this is not a flow through type, ie only 1 inlet at the bottom.
Look at an early range rover, SD1 rover etc.
The tube to the expansion tank needs to be small, 1/4" id, you just fill up, the system, make the expansion bottle large enough for around 1 pint, and half fill, stick the pressure cap on then fill the system. You can 'burp' the air out by squeezing the inlet tube.
Disco, nothing high and ugly in the engine bay.
Regards Mark
Bitten hero
posted on 3/1/08 at 09:35 PM Reply With Quote
Top man never thought of that one so just need to find a suitable tank with cap and hey presto- ps anybody know if theres a reason for not using copper tube for the metal cooling pipes that run extreamly close to the headers( sombody said that the copper has some sort of reaction to the antifreeze/coolent)????????
mark chandler
posted on 3/1/08 at 09:39 PM Reply With Quote
Plenty of copper rads about so thats rubbish. You cannot however make exhausts from copper as this will produce poisonous fumes
907
posted on 3/1/08 at 10:13 PM Reply With Quote
Regards Mark
Absolutely.
I have a sealed rad cap and a 10psi cap on the expansion bottle.
The pipe comes off the thermostat housing with another tee'd in from the rad overflow,
then into the bottom of the bottom of the expansion bottle. (see pic)
Bitten hero
posted on 3/1/08 at 10:26 PM Reply With Quote
thanks lads !!!!!!!!!!
