James
posted on 18/6/02 at 04:50 PM |
Engine Paint
I've just been looking around for some engine paint (hey, it's better than sitting at my desk working) and it's prompted a couple of questions.
1. Is there any preference to the colour or is it purely personal. I guess some (like black!) will give off heat better but the advantage of a lighter
colour (ie. silver) being you can spot any oil leaks.
2. I've been to Halfords, Les Smith and Camberley Auto Factors to compare prices and they all want £4.50-£5.00 for a poxy 250ml tin. Is there
anywhere in the Guidlford/Camberley/Farnborough area that sells it at better value?
James
Fatboy Dave
posted on 18/6/02 at 06:27 PM |
Black is better, but I always paint my engines red (except for my V8s, they get silver).
If Halfwits are too dear, try Frost Auto Restoration Techniques(!!- still love the accronym ) I think they're at
www.frost.co.uk
The paint itself isn't cheap, but it's akin to enamel, so a little goes a long way...
Dave
Stop the planet, I want to get off
Glenn
posted on 18/6/02 at 09:04 PM |
Get yourself some Hamerite Hammered finish
paint, very tuff, durable and heat resistant, about the only thing (other than paint remover) that will get it off is brake fuild but thats the same
with 99% of paints. but it is very good stuff.
Personally i like black engines but dark blue is nice.
Now send me a copy of those MK IRS measurments you have from bob
posted on 19/6/02 at 08:02 AM |
I used Hammerite on a number of parts before I realised what a heap of rubbush it is!
I've tried all sorts of surface prep before applying it - plain metal, degreased (which they say is OK), phosphated using a rust treatment prior to
painting, and even Finnegan's own anti-rust primer (the pinky-brown stuff). The Hammerite chipped off without fail.
There are a lot of better paints out there!
(POR-15, "Correct Chassis Paint" from Frosts, Chassis Black from Frosts, and many more).
For the engine you need something other than Hammerite anyway - it says on the tin that it's only for use up to a certain temperature, less than that
of an engine block.
(anyone would think that I hate Hammerite)
Glenn
posted on 19/6/02 at 10:30 AM |
Dave,
I cannot disagree that it will chip off when knocked but it is better then most stuff i have used when 2 coats are used.
As for preping, i just rub back or sand blast parts befor aplying, never had any real problems other than when somthing is very oily and even then it
seems to stick alright.
as for its tempreture resistance, i have used it on blocks, brake calipers and drums and even plastic mould tools with no problems, it just gets
harder with heat
James
posted on 19/6/02 at 02:53 PM |
Thanks for the info' guys- I'll give these a try.
Will probably go with red as have seen a couple that look good like this and it'll match the cam belt cover too.
How does it look if the gearbox is a different colour? I'd do it red too only I've always wanted a nice shiny silver gearbox!
Come to think of it, how hot does the tappet cover get? Do I need to worry about paint temperature for this?
Glenn, ssssshh, Bob was only joking about that- I don't wanna get lynched at the next car show I go to.... I'll just reply now. ;-)
Leonardo James Vinchi
stephen_gusterson
posted on 19/6/02 at 07:44 PM |
PLEASE WHATEVER YOU DO DONT PAINT YOUR ENGINE WITH HAMMERITE.
ITS SHIT.
ITS SHIT.
ITS SHIT.
If you dont beleive me, go onto the manufacturers web site. Look for the temperature rating.
It basically says 'use in places where its not too hot to touch'. So, an engine is a no no.
Also, a guy called john snowden on TOL painted his engine red, and it came out pink with hammerite.
You have been warned.
It chips easy, it stays soft for ages, it spreads like evo stick and it takes 6 weeks between coats.
other than that its fantastic.
Buy engine enamel from Halfords.
atb
steve
posted on 20/6/02 at 01:09 PM |
ITS SHIT.
ITS SHIT.
ITS SHIT.
Don't mince words Steve, tell us what you really think...
BTW: I agree totally!
mikelancsuk
posted on 20/6/02 at 03:34 PM |
Hammerite is crap.
I bought Halfrods HT Paint 250ml about 4quid, does the job and looks nice!
They also do some other colours rather than being stuck with :
Black
Black
Black and errr
Black!
stephen_gusterson
posted on 20/6/02 at 06:37 PM |
Black
Black
Black and errr
Black!
the Halfrods paint goes on nice in two coats. Hammerite does come in other colours, but hey its s^*t.
BTW - I thought this site had an auto bad word blanker outer?
atb
steve
neo
posted on 20/6/02 at 08:45 PM |
i used Halfrods HT Paint in blue it looked good at first the more you drive the blue turns brown/black
bob
posted on 20/6/02 at 09:15 PM |
The old hamerite of some years back was good,but the new stuff has a melting point of butter.
Glenn
posted on 23/6/02 at 02:27 PM |
Maybe is becasue i use the Hammered finish
stuff, but ive only ever had problems with
it when the surface hasent been clean.
Its seems to be fine on many different
engine blocks i have used, I wouldent use it on aliminum but it's always been good on
steel etc.
