Stuart_B
| posted on 8/1/08 at 06:09 PM |
Vapour separatoi
hi, is the Vapour separatoi need, as i will be runing bike carbs, and will i need to run a return pertol pipe, and what size petrol pipe do i
need???
Stuart
indykid
| posted on 8/1/08 at 07:05 PM |
you don't need the vapour separator, nor do you need a return line.
what you will need is a carbed bike fuel pump that self regulates the pressure and shuts itself off when it reaches pressure.
hth
tom
Stuart_B
| posted on 8/1/08 at 07:14 PM |
so if i keep the Vapour separatoi can i use the standed fuel pump with a return line?
Stuart
andyace
| posted on 8/1/08 at 08:12 PM |
Sorry for the hijack. I am just putting in my copper fuel line to go from front to back through the tunnel. I have a pinto with bike carbs so I
understand that I only need one pipe however I am thinking of running a spare pipe to prepare for a future upgrade. Under what situations will I need
a return pipe. I.e what engine, fuelling etc.
Many thanks Andy
indykid
| posted on 8/1/08 at 08:17 PM |
you can probably get a bike fuel pump for a tenner to £15. then you just need one fuel line and a power wire.
it'd make a lot tidier install and is the tried and tested method. i don't think the vapour seperator is a pressure regulator, so
you'd probably need one of those too. i'd do anything to save running a return line as then you get into extra tank connections and all
sorts of other complications.
tom
Stuart_B
| posted on 8/1/08 at 08:54 PM |
thanks tom for the help will have a look for a fuel pump, does it have to come from a 600 as i got cbr600 carbs??
and of the topic, but does a 1.6 pinto go well in a indy?
Thank you
Stuart
Danozeman
| posted on 8/1/08 at 09:42 PM |
Any bike pump will be ok. Make sure its a carb'd bike pump not a fuel injected bike pump. The FI ones run at much higher pressure.
Dan
Dingz
| posted on 8/1/08 at 11:41 PM |
Or just use the pinto pump with a pressure regulator.
Stuart_B
| posted on 9/1/08 at 01:28 PM |
so what size pipe do i run?
Thank you
Stuart
indykid
| posted on 10/1/08 at 03:01 PM |
i've used 8mm copper microbore from tank to engine bay.
it depends what the unions are on your pump as to what you need to do from there. i used a thundercat pump for my blade carbs, which has 10mm
connections. therefore it needed a 10-8mm reducer on the end of the microbore to increase the size for the hose to clamp to. then i just ran it on
10mm i/d rubber from copper to pump, pump to carbs. the pump's infront of the nearside engine mount btw.
a 1600 pinto's more than adequate to make a 7 go. it's not nearly as rapid as a BEC or even a 2.0 pinto, but it'll still put a smile
on your face. i started with a 1600 because i was 19 when i first insured it. now i'm thinking of going 2.0, but i think i'll run it for
another summer on the 1600.
tom
Stuart_B
| posted on 10/1/08 at 03:26 PM |
thanks tom, i was wondering the pump goes, as i got a cbr600 pump for my bike carbs.
As well i am going for a 1600 pinto as it will be my first car.
Stuart
