Author: Subject: VAUXHALL XE crank seal leaking
TOO BADD
posted on 15/1/08 at 08:54 PM Reply With Quote
I have an Vaux XE in my ST and wonder if there is anyone out there with the same engine. It is 2.1, full race head, ( autosprint ) steel rods, turbo bearings, omega 11.5:1, H&H ignition, and 45 mm dellortos.
I have rebuilt this engine 3 times over 4 years and it is tuned for excellent low down power. Question is, is there any fix to stop the rear crank seal from leaking ?
MikeR
posted on 15/1/08 at 09:28 PM Reply With Quote
Ask NS Dev, he's got a bit of experience with the XE engine.
gregf27
posted on 15/1/08 at 09:39 PM Reply With Quote
Have recently rebuilt my vaux xe , it was recommended to me from quite a few sources to use the original GM crank seal from vauxhall as well as their sealant to cure the problem - I can dig out the sealant number for you tomorrow eve if ya need it ( got it from e-bay originally ) thick black sticky stuff!!!
regards,
Greg
cidersurfer
posted on 15/1/08 at 09:44 PM Reply With Quote
The Vauxhall sealant is the stuff to use. Also on a well used engine it's also not unknown for the oil seal to cause wear on the crank, worth a check, some have got away with giving it a polish and the leak has disappeared...
shimming solid lifters is a job for a friend...
TOO BADD
posted on 15/1/08 at 11:15 PM Reply With Quote
Thanks for the replys. The crank has only done 4000 miles so as for the seal wearing a mark on it probably is unlikely.
I have'nt used a geniune seal and black sealer before so thats worth a go Greg.
I did wonder if because, as its a heavy clutch there is more 'push' force on the flywheel, that maybe there is just enough movement to slighly displace the ptfe coating the seal lays on initial start up. The last block build up was performed by a local engineers shop that have been doing this kind of work since they invented the wheel and they probably used a Wurth sealer. Engine coming out soon to send the box back to BGH for a slightly different set of ratios so will do seal then.
NS Dev
posted on 16/1/08 at 08:29 AM Reply With Quote
Must admit never had a rear seal leak. Had a couple of front seals let go, both times after the car had been pressure washed and let stand, rust crept under the ring on the crankshaft.
As others have said, it could be the seal or it could be the sealer between the rear main bearing cap and the block.
either way its an engine out, gearbox off job.
NS Dev
posted on 16/1/08 at 08:30 AM Reply With Quote
ps I never use the vauxhall sealant, I use "Rhodorseal" and have never had a problem.
TOO BADD
posted on 17/1/08 at 08:53 PM Reply With Quote
Thanks. Nothing against Vauxhall but been on the Rhodorseal website and it certainly looks good. I take it, it is the 5661. Prob take out eng/box end of Feb as the r/tax expires and then send the box to BGH at the same time for a slight change of ratios.
NS Dev
posted on 20/1/08 at 09:43 PM Reply With Quote
5661 thats the stuff
