r1_pete
| posted on 16/1/08 at 09:15 AM |
Idler pulley advice
I need to add an idler pulley to my phase 3 zetec install to run the coolant pump anticlock. When the belt wraps round the pulley with the v grooves
inwards, do I need a grooved pulley, or will a plain one be ok? I've looked at pics of the westfield one and that looks plain but cant be
sure.
Cheers.
Pete.
| posted on 16/1/08 at 09:45 AM |
It should be a grooved pulley....
Otherwise the contact area will only be the end of the grooves. This could lead to slipping and early wear to the belt.....
indykid
| posted on 16/1/08 at 12:01 PM |
if it's just an idler pulley, surely there'd be very little resistance, so no torque would be transmitted at the interface.
i'd be more swayed to it being ok as long as it's not driving anything.
tom
| posted on 16/1/08 at 12:31 PM |
There is little resistance so you might get away with it.... Then again....
Slippage is a worry though. After all, the multirib belt is only prevented from slipping (unless you've got shouldered plain idler pulleys) but
the ribs on the other pulleys. If you start replacing them with plain pulleys you might get lateral belt slip
r1_pete
| posted on 16/1/08 at 12:41 PM |
It is just an idler, wont be driving anything, just serving to wrap the belt round the coolant pump pulley to provide a good contact area like this:
r1_pete
| posted on 16/1/08 at 12:42 PM |
tim windmill
| posted on 16/1/08 at 01:29 PM |
i am using the zetec blacktop and i have removed the original tension pulley and butchered this a bit and have mounted this at the other side to act
as the idler pulley. It seems to work okay but have not driven in real anger yet
r1_pete
| posted on 16/1/08 at 02:18 PM |
Thanks, I dont have the original idler, is it v'd or plain? might be easiest to buy one if its v'd, rather than spending a couple of hours
at the lathe....
Cheers.
Pete.
FazerBob
| posted on 16/1/08 at 08:30 PM |
Idler pulley
I had the same problem with my Zetec, but found a different solution. First changed the pump for an Escort one (which runs clockwise) then a quick
visit to the local scrappy for an Escort Zetec water pump pulley (£5). The belt now runs safely round crank, alternator and water pump, with no idler
needed.
Bob
Schrodinger
| posted on 16/1/08 at 09:37 PM |
There isn't an escort water pump that fits the blacktop.
Keith
Aviemore
stevebubs
| posted on 17/1/08 at 01:00 PM |
I originally left the original power steering pump in place to maintain belt patter, but running it dry (unsurprisingly) led to the bearings in the
pump melting.
I then ran mine the wrong way (v's of the belt on a flat pulley) for a few weeks before the inverted impellor turned up from the states.
Temperatures at the time were low 20s and I had no issues (was running car in prior to Le Mans). However I wouldn't have felt happy running in
that configuration for a prolonged period of time - hence swapping it out.
If using the original pump, I have heard of escort and fiesta idlers being fitted in the Power Steering pump location. Perhaps worth a trip down the
scrappies and having a look around.
stevebubs
| posted on 17/1/08 at 01:04 PM |
Setup below is not recommended - power steering pulley bearings will melt within a short period of time
stevebubs
| posted on 17/1/08 at 01:08 PM |
One other novel solution I've seen is have an alternator mounted in the power steering position. However, instead of mounting the body of the
alternator next to the engine, it was mounted sticking forward (i.e. facing the "wrong way", with the power connectors towards the front
of the car)
Look at www.zetec-cat.co.uk for ideas on how to fabricate an effective idler/tensioner assembly.
