Author: Subject: Easiest Bike Engine Set Up
Loco_Bill
posted on 16/1/08 at 10:34 PM Reply With Quote
Hi guys,
I've been searching on here for quite a while now, trying to soak in all the (useful)information on what engine to go for. I have decided I definitely wanna go for the bike engine route. I'm building a haynes roadster (new book) and just finished welding the chassis.
Now i'm a bit new to bike engnes (never ridden one) and was wondering what you think the best engine to fit - bearing in mind i'd like it as hassle free as possible i.e no dry sump.
I really like ZX12Rs but understand there no quite so easy to fit as an R1 or ZX10.
With out causing any scrapping between you all, whats best to go for?
[Edited on 16/1/08 by Loco_Bill]
zxrlocost
posted on 16/1/08 at 10:40 PM Reply With Quote
to get you going R1 carb engine 5jj
almost fuel injection power with half the loom
hth chris
bigrich
posted on 16/1/08 at 10:55 PM Reply With Quote
from personal experience a carbed blade is about as easy as it gets, zx10r is more involved wiring wise, but not that much more difficult just more expensive really.
zx12r is a good lump slightly heavy but is proving reliable Q team hellfire
Rich
pictures of both in my archive if you want to have a look 919 blade and 2006 ZX10r
caber
posted on 16/1/08 at 11:04 PM Reply With Quote
Just get the bike carbs and put a car engine in, far easier
Caber
zxrlocost
posted on 16/1/08 at 11:06 PM Reply With Quote
rich is right the fireblade carb is even easier to get going
r1 is still easy
worX
posted on 16/1/08 at 11:38 PM Reply With Quote
I'd say Carb'd FireBlade engine (and not just because I have one). They are slightly more reliable than most others, the wiring is very easy to sort and the cooling system is the easiest ever!
Loco_Bill
posted on 16/1/08 at 11:49 PM Reply With Quote
Cheers for all the input guys
I think i definitely wanna go fuel injected as i believe theres more potential for fine set up tuning and management. Electronics and Wiring looms don't scare me too much, its more all this chopping the sump up and complicated cooling systems.
worX
posted on 17/1/08 at 12:27 AM Reply With Quote
Then you ought to start thinking ZX10R and locating a freelander diff!
posted on 17/1/08 at 12:51 AM Reply With Quote
As I've wired an early blade and a ZX12R i can confess the blade in comparison was a doddle. However, the ZX12R wasn't too difficult once I'd got my head around it... wiring apart, there's little difference between them.
Both examples on our website...
[Edited on 17-1-08 by Hellfire]
nitram38
posted on 17/1/08 at 11:34 AM Reply With Quote
Although less wiring on any carb bec, aren't emissions then an issue?
Rejetting and rolling road costs?
I have an 05 R1 inj with power commander and innovate lambda gauge.
It might be a little more expensive but tuning should be a diy job.
Keeping an eye on the lambda gauge and having the power commander will mean re-tuning as I drive.
A rolling road cannot simmulate air flow into the engine so what might work on the rolling road might be running too lean/rich on the road.
Having a rear engine I am retaining the standard airbox, but ducting 2 NACA scoops via 3" hose to hopefully give a bit of "ram air". This means that the rolling road tuning might be out. That's my theory anyway!
Coose
posted on 17/1/08 at 11:58 AM Reply With Quote
It's even easier if have either a designated passenger who understands Power Commander software, or a driver whilst you passenger!
Spin 'er off Well...
NS Dev
posted on 17/1/08 at 12:38 PM Reply With Quote
As long as you are not bothered by the electonics (and there is no need to be) then as Hellfire suggests, the ZX12r has a lot going for it.
Certainly go for the most cc you can, you need it!
Bob C
posted on 17/1/08 at 11:49 PM Reply With Quote
I'd second the carb R1 recommendation if FI electronics is a worry - the final drive ratio is as car friendly as bikes get, it's light & easy to mount & I got mine through SVA emissions tests with just a cat (no other 'mixture' bits added) which I subsequently sold on (smoke test only for MOT on a Q)
Bob
