Author: Subject: New cam
jos
posted on 17/1/08 at 07:41 PM Reply With Quote
New cam
Can i just buy a new cam on its own and fit it to my engine or should i buy new valve springs doobery firkins and widgets to go on it too???
Dingz
posted on 17/1/08 at 07:45 PM Reply With Quote
At least fit new followers, otherwise you may have to replace both the cam and followers after a little while
posted on 17/1/08 at 07:49 PM Reply With Quote
Always fit new followers at least Also depending on what cam you may need different springs. Your cam supplier should be able to advise.
snapper
posted on 17/1/08 at 08:24 PM Reply With Quote
I agree that a complete cam kit with new springs and followers and spray bar is the way to go.
Also worth checking your cam bearings.
I eat to survive
I drink to forget
worX
posted on 17/1/08 at 11:26 PM Reply With Quote
No Jos, stick with a standard cam - Well standard in the Bike Engine that you should swap it for, instead of that Pinto!
