Author: Subject: Cool pinto spraying oil
Shamrock GS
posted on 19/1/08 at 09:59 PM Reply With Quote
After 2 months of tearing my hair out the beast finally sits at the right temperature. It took a new water pump, thermostat, replacement hoses and temperature sender but finally I can go more than 10 miles without a stop to cool down.
Only issue now is oil spraying out of the rocker cover (a new problem but since everything else seems to be working no great surprise). It seems to be coming past the bung in the hole where you pour the oil (relocated at the back of the engine) - should I be worried?
Gary
Sun Tzu, The Art of War
meany
posted on 19/1/08 at 10:06 PM Reply With Quote
yeah, it will get messy..
cant you weld in a baffle plate to stop it happening...im sure someone has a pic of howto
jacko
posted on 19/1/08 at 10:11 PM Reply With Quote
do a search under darren w name + how have you got your crank breather set up ? have you removed the one way valve that will stop your problem i feel certain
Jacko
ps do you have a photo of the r/cover
snapper
posted on 20/1/08 at 09:16 AM Reply With Quote
fit a baffle first then if that does not cure it completely start with the breathers and a catch tank.
I eat to survive
I drink to forget
viatron
posted on 20/1/08 at 09:30 AM Reply With Quote
I dont think a baffle will cure this, if you have oil coming out from the oil filler cap (Im guessing its one of the plastic affairs with wire wool or like inside?) then you have either a breather issue or very very very worn bores!! gulp! How have you got the breather system set up?
Mr Whippy
posted on 20/1/08 at 11:55 AM Reply With Quote
I welded a plate inside the cover across the filler hole, yes there's still a gap to pour oil in but it did stop the oil coming out the filler cap.
