Avoneer
| posted on 20/1/08 at 11:10 AM |
Shell VPower
Hi All,
Anyone used any of this or know if it would upset a blade engine?
Pat...
thunderace
| posted on 20/1/08 at 11:47 AM |
just type in google review shell v power
i use it in my bmw r850r motorbike with no problems.
Dangle_kt
| posted on 20/1/08 at 12:23 PM |
I dont know v power in particilar, but if it is similar to all the other posh fuels on forecourt then your wasting your money.
All they do is have a higher RON rating, which means it will not preignite as easily (KNOCK) which wont be a problem in your blade unless you have
up'd the compression considerabley.
Works on certain bikes that have higher compression ratio, like some of the latest BMW's.
RazMan
| posted on 20/1/08 at 02:07 PM |
If you remap your engine you might get some small benefit but otherwise you are just burning more £s per mile imo.
Raz
Danozeman
| posted on 20/1/08 at 02:13 PM |
I always found the higher ron fuel used to use it twice as quick and to no real gain.
A bottle of octane boost works out cheaper i think.
Wheni felt rich i used to put it on my Fiesta zetec-s. It did 190 miles to tank instead of 300 and i drove it no different.
[Edited on 20/1/08 by Danozeman]
Dan
tks
| posted on 20/1/08 at 02:40 PM |
dunno if its logic or not, but if you put more octane in a liter of petrol then there should be less room for petrol it self??
(the stuff that burns..??)..
sow kind a logic..
Tks
RazMan
| posted on 20/1/08 at 02:44 PM |
Raz
snapper
| posted on 20/1/08 at 02:55 PM |
With the older engines such as the Pinto and the Crossflow, when unleaded and LRP came in you had to retard your ignition by 2 to 4 degrees thus
loosing power, higher RON fuel allows you to advance the ignition and regain the lost power.
If you already run unleaded and the engine does not knock then extra RON wont help much.
I do know that some engines with knock sensors can be set up to advance more for the higher RON fuels thus giving you a bit more power.
However the engine should be set up for the fuel used and to get the benefit of the higher RON fuels an increase in compression ratio is needed.
I eat to survive
I drink to forget
flak monkey
| posted on 20/1/08 at 03:01 PM |
V power makes a noticeable difference on my old pinto, but doesnt seem to make any difference on any of the modern cars I drive.
Sera
http://www.motosera.com
Coose
| posted on 20/1/08 at 06:53 PM |
Nope, don't bother in any stock Japanese BEC (i.e. nothing more than filter and exhaust mods).
Spin 'er off Well...
Bob C
| posted on 20/1/08 at 10:52 PM |
" if you put more octane in a liter of petrol then there should be less room for petrol "
that's true of "octane booster", though thay can be (e.g. toluene) fuels in themselves.
I was always under the impression that petrol WAS octane, i.e hydrocarbon CH4 is methane, then C2H6 is ethane, onwards & upward though pentane,
hexane until you get to C8H18 which is octane.
I would not be surprised if I were utterly wrong about this......
PS I was largely right
http://en.wikipedia.org/wiki/Octane
[Edited on 20/1/08 by Bob C]
