Author: Subject: Silicon hoses
Northy
posted on 19/10/03 at 07:31 PM Reply With Quote
Silicon hoses
Hi everyone,
Two questions for you.
I've seen that silicon hoses come in lots of different diameters. How easy is it to force a hose that is slightly too small onto an outlet? Also, how easily will a hose that is slightly too big squash down onto a smaller outlet? My problem is this, outlet on thermostat housing, and inlet on the pump are both 34mm diameter, both inlet and outlet on the rad are 31 1/2 mm. Do i really need to buy reducers etc?
Secondly, where is the cheapest place to buy them? I've noticed Demon Thieves are more expensive than Rally Design. Anyone know anywhere else?
Graham
Stu16v
posted on 19/10/03 at 09:21 PM Reply With Quote
Silicon hoses can be purchased with differing diameter ends IIRC.....
skippad
posted on 19/10/03 at 11:46 PM Reply With Quote
silicon hoses
You have a supplier on your doorstep...
Motorscope at Northallerton, cheaper than Demon Chirps.
bob
posted on 20/10/03 at 08:17 AM Reply With Quote
http://www.thinkauto.com
i've had a few bits from them,prices are ok for what i needed.
Nice people too and very helpfull.
Northy
posted on 20/10/03 at 05:37 PM Reply With Quote
Cheers guys,
But how well can they be made to fit slightly under / over size inlets and outlets?
Graham
Stu16v
posted on 20/10/03 at 06:25 PM Reply With Quote
See above....
Northy
posted on 20/10/03 at 07:49 PM Reply With Quote
But only in short lengths, as I said earlier, reducers. Its just I could imagine normal rubber pipes being forced onto slightly too big outlets, and nipped up on those that are slightly too small.
Just wondered how pliable a Silicon hose was
Graham
