GaryM
| posted on 20/1/08 at 04:50 PM |
Xflow inlet port spacing?
Hiya
Does anyone know what the inlet port spacing on a xflow head should be?
Gary
DavidM
| posted on 20/1/08 at 05:36 PM |
It's difficult to measure accurately on the head because of the angle of the ports. I've just measured a standard inlet manifold and it is
99mm - 93mm - 99mm.
Hope this helps.
GaryM
| posted on 20/1/08 at 07:37 PM |
Thanks David
| posted on 20/1/08 at 09:18 PM |
Use an inlet manifold gasket as a pattern if you are making a manifold, worked for me.
